Old 04-07-2008, 10:47 AM
manyrains manyrains is offline
Default \"playing Strike\"
Haven't had time for much recording lately, so I'm just getting my head back into learning how to work with Strike.
I've got a drum track written on the instrument track. To date, I have never recorded the instrument to audio track (haven't finished a real song yet since getting Strike). To use the complexity and intensity controls, am I correct in assuming this would be accomplished by playing them in real time as I'm recording to audio?
If so, although I'm sure I'll figure it out, if someone wouldn't mind telling how to record the instrument track to audio. (I'm assuming it's a simple bus/ input between the two tracks?)
Thanks
www.jimsavage.net
www.manyrainsmedia.com
Mac Pro Late 2013, 3.7, 12GB, Apollo Twin, PT12, ADL 600, UA 2-1176, Mojave MA-200
Old 04-07-2008, 11:23 AM
spkguitar's Avatar
Default Re: \"playing Strike\"
Try My Tutorial.
Old 04-07-2008, 05:25 PM
Len8 Len8 is offline
You can leave the drums as midi triggering Strike and then it'll turn to audio when you bounce to disk. As far as the controls, just add automation points to the midi track.
Old 04-07-2008, 05:33 PM
LSW LSW is offline
Thanks
How attached are you to the drum track? Is it something you programmed via midi before getting Strike, or while using Strike as the sound source?
The reason I ask is, you may want to consider rebuilding your track in the module itself and use its full potential. Its timing resolution is greater than that of MIDI, so you'll get a much better overall feel. And, at least in my opinion, tweaking the patterns, styles and kits are wayy easier than programming MIDI by hand or even with pads or a controller.
Old 04-08-2008, 08:42 AM
Yes, I built the track with Strike. I'm just wondering if I want to change the complexity or intensity settings during the song, how is this done. Realtime, i.e. "playing", or is there some way to automate changes with the complexity/intensity dials/faders.
www.jimsavage.net
Old 04-08-2008, 10:03 AM
citi citi is offline
Record in midi merge mode and do you complexity changes via your midi controller. Yes, it will be real time. That's really where strike shines. If acts like a real drummer.
CiTi
http://www.checkonet2ent.com
Old 04-08-2008, 08:08 PM
manyrains, make sure you assign Hit Types, Timing Offsets and the Complexity Threshold to those Instrument Hits you want control of in real-time.
filosofem
Aaron Mulqueen - 001 HD Native
Old 04-09-2008, 02:51 PM
Thanks for the point. Don't know what it means, but I bet I'll figure it out! Or, maybe not...
www.jimsavage.net
Old 04-09-2008, 09:08 PM
You'd look those up in the Strike Plug-In Guide.
filosofem
Old 04-11-2008, 07:34 PM
Oh, yeah, I knew that....
www.jimsavage.net
Problem with Strike 1.5-Pro tools 10 wants to move Strike.dpm to unused folder. We live forever Virtual Instruments 55 09-17-2012 06:02 PM
Playing a SMF with Strike DonaldM Virtual Instruments 6 09-10-2012 12:48 PM
Opinions please - Does Strike come with enough different playing styles? stpete111 The Drum Room 3 05-23-2011 11:28 AM
Strike not playing well with playback engine idleave Virtual Instruments 10 09-23-2009 07:18 AM
Strike missing beats and playing wierd stuff!! Audiorayne Virtual Instruments 5 03-04-2008 10:58 AM
