Old 03-07-2024, 11:31 PM
omidmash omidmash is offline
Default Playback engine swap without restarting PT
Is there any chance of getting this feature in the future? I use an audio interface and a digital mixer, and use my digital mixer when I am tracking, but don't want to spool up the whole thing just when I am doing the mixing part later, and this always leads to having to restart PT. With bigger projects, this is a inconvenience.
Old 03-08-2024, 03:04 AM
Default Re: Playback engine swap without restarting PT
That would likely be a complex disruptive mess to implement for a corner case use. So I'll go with a big nope on that.
Old 03-08-2024, 12:17 PM
BScout BScout is offline
No for your basic question.
When the audio engine changes, the I/O changes (and in some cases, like switching to HDX, the mixer changes.) Can't have that change while Pro Tools is open and have all those settings change.
For your use scenario, you've told us nothing about what system or what PT version you are running. If on a Mac, with the right versions of Pro Tools, you can use 2 audio interfaces simultaneously by assigning one to be the "aux" interface (most likely your tracking interface) and leave your digital mixer as your main playback engine.
Old 03-08-2024, 01:16 PM
dominicperry dominicperry is offline
There's no fundamental reason I can see why this couldn't happen - other DAWs allow a change of audio device (including I/O assignments) without shutting down, but PT does not. I suspect, under the hood, it may be a difficult change.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 03-08-2024, 01:35 PM
Dominic
Other DAWs don't have hardware DSP mixer integration (well, one incomplete one does) where the paradigm completely shifts. From the beginning of the DAW to today.
Old 03-08-2024, 03:04 PM
Eric Lambert's Avatar
Dominic
They could, technically, but as you've suggested it would require some large changes which they've not deemed necessary. Restarting PT has been an acceptable step for most. PT loads quickly enough that it doesn't bother me.
Old 03-08-2024, 11:00 PM
There is no fundamental reason I can see why Scarlett Johansson is not going to date me. ¯\_(ツ)_/¯
HD Native Thunderbolt Engine is not being retained when selected as Playback Engine antonis Pro Tools HDX & HD Native Systems (Mac) 0 01-08-2022 01:07 PM
playback cuts out with plenty of CPU power left, have to change playback engine jmac146 Pro Tools 11 7 10-02-2016 11:34 AM
Playback Engine Issue (Won’t load session with chosen playback engine) MattyJones Pro Tools 11 0 11-02-2015 11:52 AM
Playback Engine>Current Engine issue Hunterkiss macOS 0 06-28-2013 01:14 PM
No m-audio interface in current engine (playback engine) SlicerSounds Windows 1 10-04-2012 12:27 AM
