Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 04-20-2015, 07:14 PM
amagras amagras is offline
Default Re: "Current playback engine does not support a sample rate of 48 khz"
Or you can just connect a pair of headphones on the front panel... I'm still looking for a permanent solution, maybe disabling the the default audio drivers?
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 04-20-2015, 08:31 PM
Top Jimmy's Avatar
Disabling onboard audio would force windows to use your audio interface which is what you don't want it to do. Auto jack sensing is a PITA. I've tried disabling it in the registry but I haven't been successful with that method. My workaround was to cut the ends off some old broken headphones and leave them plugged into an onboard in and out. Windows thinks something is plugged in so there's never a problem.
James Cadwallader
Old 04-20-2015, 08:42 PM
Exactly Jimmy, that seems to be the solution for all of us having this problem. I wonder why exactly is this happening? Never heard of other software having this problem.
amagrasmusic.com
Old 04-20-2015, 11:17 PM
mesaone mesaone is offline
Don't blame Pro Tools. This is a problem related to how ASIO drivers handle multiple simultaneous clients. http://www.soundonsound.com/sos/nov9...pcmusician.htm
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 04-24-2015, 06:53 AM
YYR123's Avatar
YYR123 YYR123 is offline
nor AISO b/c Microsoft didn't (should have) support(ed) / pushed a standard audio driver out of the box back in the early days.
Daniel
  #16
Old 04-24-2015, 08:41 AM
Notice how old that article is. You're right, it's horrendous how little progress has been made on Windows. But when it works, it works. I just wish ASIO was as elegant as CoreAudio.
  #17
Old 05-29-2015, 01:03 PM
Amack Amack is offline
Default
Never blame Pro Tools, despite all contradictory evidence.
  #18
Old 05-29-2015, 01:22 PM
YYR123's Avatar
Default
Doesn't Win10 come out with a new Windows Standard Driver? Audio of course
Daniel
  #19
Old 05-29-2015, 01:30 PM
Default
What's your point? Is Windows 10 out yet?
  #20
Old 05-29-2015, 01:31 PM
YYR123's Avatar
Default
Supposed to be, or will be in the next month....
Point is......things are changing on the ProTools front and possibly for the better for the windows users
Daniel
"The current playback engine does not support a sample rate of 48 KHz" error when tr eyeshow Pro Tools M-Powered (Win) 19 09-09-2015 10:10 AM
The current playback engine does not support a sample rate of 48 kHz oNeKOG Third Party Interfaces 3 09-08-2014 04:36 PM
the current playback engine does not support a sample rate of 47.9 kHz mikevarela Post - Surround - Video 3 03-30-2013 09:26 AM
"The current playback engine does not support a sample rate of 48 KHz" E-Lister Windows 3 02-25-2012 11:54 AM
"The current playback engine does not support a bit rate of 48kHZ" M-powered 8 beasleymusic Pro Tools M-Powered (Win) 1 04-02-2011 03:17 PM
