DAE 6101 on new iMac
So, I'm getting the dreaded 6101 (cpu overload) error on my brand new imac. Im running the latest pro tools 10 & 11 version on Mountain lion 10.8.5. I know that avid has yet to fully suport 10.8.5, but on my laptop it runs perfectly smooth. Also it seems like others are having success with it. No matter what I do (lower buffer size, track counts, plugins etc.) I still get the error during playback even though my imac spe is perfectly fine to handle heavier loads.
So, I need to know whether others are facing the same issue with the latest osx or whether my imac is at fault. Ive tried uninstalling and re-installing pro tools and did a complete factory reset on my imac and its the same error. I would much appreciate any feedback back, thanks. *Late 2013 imac, 3.5ghz i7, 8gb ram, 1tb fusion drive running 10.8.5 osx with pro tools 10.3.7 with Pro Tools Aggregate i/o **I've attached a screenshot of one of my session settingsScreen Shot 2013-10-12 at 4.13.42 PM.jpg |
Re: DAE 6101 on new iMac
Still on OSX 10.8.4 on the system in my sig file and on the odd occasion I get 6101 errors while playing back a session but I can stop playback, go back to the start of the session, restart playback and not get the error at all. If it doesn't happen constantly I'd not worry about it.
Have you done all the optimizations for your computer? Working with separate hard drives for your sessions? Also give it a shot without aggregate I/O. What exactly is you audio I/O setup - you may not need to run aggregate as that has been a problem on Macs from time to time. |
Thanks for replying. Yeah I've tried all the optimization, but still nothing. Im aware you get these errors once in a blue, but this happens everytime I try to get playback. Im aware you should use another disk other then your main drive, but this is a 1tb fusion drive with plenty of space. I've tried using the other i/o configurations like built in/speaker i/o's, but still nothing. I wonder if any others with a 2013 27' imac are having similar issues. Perhaps issues conflicting with the nvidia 775m graphic card?
Last edited by solo206; 10-13-2013 at 06:11 AM. Reason: wrong graphic card posted |
No problems here, yet😚
Sent from my iPhone using Tapatalk.
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey Alesis Masterlink, Alesis Adat LX20, , Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon, Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric. http://www.johnackermusic.com/ [email protected] Live and Let Live |
You say you've done all the optimizations - turn off Spotlight, turned off any power savings like sleep, etc.? The graphics card has nothing to do with this. What other audio I/O options have you tried besides the built-in? You mentioned aggregate audio - that means using several audio interfaces, whether it's a combo of internal and external interfaces, multiple external interfaces, etc. |
But I digress, if only slightly. A Fusion Drive is an SSD and a traditional HDD that are fused together by CoreStorage. So you actually have two sets of read/write heads, one per physical volume. The issue is that to Pro Tools, the OS, or any other program, the volume you created with the Fusion Drive appears and is addressed as a single volume. Pro Tools cannot tell the OS "let me use the SSD for this session". The OS determines which files you access most frequently and moves them to the SSD if they are on the HDD. You would have to use your session document and its audio files enough (a subjective term) to get them moved to the SSD. If you have PT11 HD or PT10 HD or PT10 with CPTK, you can use the Disk Cache and probably mitigate this problem. Having said that, Disk Cache is not an excuse to skimp on a 7200 RPM drive. It's just a means of getting better performance and working with volumes that are hosted on a SAN or served as NAS.
Would disk cache in HD really help on recording? I thought that was mainly a playback helper. |
Agreed. The point is that with 1 read/write head, doing any session work on the Macintosh HD is a bad idea and is unsupported by Avid.
-6101 | AdamPT8 | macOS | 2 | 04-15-2011 11:34 AM |
No more -6101 issues... | 11miles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-15-2009 01:02 PM |
DAE error 6101 and Imac | johan2006 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 04-23-2009 08:50 AM |
CPU Overload Error (-6101) on intel imac | mack122 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-05-2007 02:12 PM |
-6101 | kneegrow | Pro Tools M-Powered (Mac) | 5 | 05-05-2006 12:22 PM |
