Re: Why is Saffire Mix Control fighting with Pro Tools
Hey,
It may be that specific drive that's causing you grief. What year is you MBP? Do you not have a Thunderbolt port? I had my system built as a turnkey, and the tech couldn't get my saffire to play nice in a a daisy chain situation. This resulted in putting my Glyph 800FW drive on my ONLY FW port, and using a THunderbolt/FW 800 adapter and a FW800-400 cable. Things worked that way. After doing much reading, I just bit the bullet and managed to get the drive and saffire to daisy chain and work. I do get the odd PT crash, but it's very infrequent. You said the LS56 mix control runs fine in standalone mode? but then gets glitchy in PT's? Sounds like your clocking is set up properly. How do you have your command 8 connected? Have you tried deleting your prefs/databases? doing a disk repair and rebooting? Have you considered rolling back to PT 10.3.2? that seems to be the most stable setup for me
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors Last edited by dr_daw; 06-03-2013 at 02:21 PM. Reason: Added question |
Okay, I did a bunch of different stress tests on all my drives, and its just my main one that creates the problem. So it is a drive specific problem. The drive is qualified and has been my workhorse for the past few years, but for whatever reason, The Saffire doesn't like it.
As a further test, I attached the Saffire through the problem drive, but ran a session from my OS drive, and the Saffire was good. It can use the drives bus, it just won't do it while audio is also passing from the drive. I've only tried all of this with a single armed track, but will try 8 simultaneous in a few. Also, The MBP is brand new I use the thunderbolt for a monitor about half the time. The Command 8 is set up at a MIDI peripheral and is connected via a USB hub. I did a disk repair and my OS drive and FW drive, trashed prefs and databases, did a reboot and still have the problem with that drive. |
I just did 8 simultaneously with the Saffire plugged into a different hard drive and all was good. :)
Now I have to learn Mix control, but that's the fun part I've been trying to get to. Thanks for everyone's help. |
To each his own, but I would not use a drive that's more than three years old for anything other than backup or archiving purposes. While I have a few drives around that have been running continuously for seven or eight years, they're only used as backups of backups, or as backups of backups of backups. In my opinion, after using a drive for three years you're running on borrowed time, and with drive prices being so low, why risk it? Of course, YMMV...
X Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...) Just rockin'...what more is there? Bill in Pittsburgh |
Agreed. I wasn't saying this is still my main drive. Just that it has been recently and I know it to function properly. I used it to test with because it has all the sessions that I want to see run on my new system.
#16
Darryl |
#17
Enjoy Mix control, I find it great, especially the 'loopback' feature can be super useful. Let me know if you get the 'play/pause' mode that I sometimes get. I've still been trying to figure out what the issue is and if anyone else if having it. If you do get that, just go into the Mix Control settings, change the buffer size and change it back, and you should be good to go. I think it's an issue if you have your LS56 setup as system sound, and you don't strictly follow the boot up sequence. So far, I haven't had it with MC 3.2, but it was a regular issue prior to that.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
#18
#19
When you go here: http://us.focusrite.com/firewire-aud...e-56/downloads and you click 'click here for more details' under the RTAS Mix Control 1.0 heading, it says: Requirements: - Saffire MixControl 2.4 or later installed - Pro Tools 9 installed Note that multiple Saffires are not supported at the moment. Please consult the RTAS MC User Guide for further information. Known issues: - Not loading between tracking and playback snapshot under certain conditions in some systems (Windows only) I'm not sure if that means you can only run it with PT9 or if you just have to have at the least PT 9. |
#20
No it works just fine. Emcha seems to have the use of it dialed. I personally don't use it because I find it a PITA. I either just deal with the latency when over dubbing or just nail the parts in one take :P LMAO I mean comp the parts :P
Focusrite Saffire Pro 40 and Command|8 Control Surface | EmperorMusic | Third Party Interfaces | 2 | 02-15-2014 11:22 AM |
Pro tools 10/11 with LS Saffire 56 | bburch88 | Pro Tools 11 | 7 | 11-20-2013 04:15 PM |
Help Pro Tools 10 and Saffire Pro 40 | sventic | Third Party Interfaces | 6 | 04-11-2013 04:19 PM |
Pt 10+ liquid saffire 56+ saffire pro 40 masterclock? | Nightworker | Pro Tools 10 | 16 | 12-08-2012 10:29 PM |
New Focusrite Saffire Mix Control 3.0 Available | cwsand | Windows | 2 | 06-30-2012 10:02 AM |
