Pro Tools Wont Even Load PATHETIC.
So, finally got Windows 7 and Pro Tools 10.3 after realising it wouldn't run on Windows 8 Beta...
Did ALL optimizations AVID listed, installed PT10.3 as Administrator, run as Administrator, good. Create a blank session, CRASHES, ACCESS VIOLATION. Try to close PT, INFINITE ACCESS VIOLATIONS, have to close using task manager. Try to open a recent session file from uni, CRASHES WHILST LOADING BUS 127-128. Try a blank session again, actually works for a second, try creating new mono track, ACCESS VIOLATION, HANGS. This is a brand new CLEAN Windows 7 Service pack 1 install, only the required mobo drivers etc installed as it is designed to be a PT system only, nothing else. I've tried clearing prefs etc as instructed on Google, NOTHING WORKS. What the hell is wrong with PT!?? I'm actually going out of my mind here trying things. I have not been filled with any confidence by this so far, seems like a TOTALLY lazy MAC port. Someone please enlighten me as to what I'm supposed to do to just get it to work |
Re: Pro Tools Wont Even Load PATHETIC.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
Well thank you, I think that's the first helpful reply I've had on these forums. I usually just get sarcasm or trolls.
Ok, custom built PC, nothing fruity, Samsung 830 SSD is my C-drive, 1115 socket i5, Mini ITX mobo, 8GB 1333 RAM, 450w PSU, Sapphire 6850 GPU. Audio Interface = Focusrite 2i2, fully working and the only audio option not disabled in Windows. Nothing wrong computer hardware wise, temps etc. Installed Windows 7 service pack 1 haven't done any Windows updates yet. Everything is clean. Last edited by JamesClark1991; 11-13-2012 at 04:52 PM. Reason: . |
SiSoftware Sandra
ID Host Name : ProTools-PC Workgroup : WORKGROUP Computer Model : OEM Serial Number : To Be Fille*********** Chassis : Desktop Mainboard : ASRock H67M-ITX BIOS : AMI (OEM) P2.20 05/31/2012 Intel vPro : 8.00.02.1410 Total Memory : 8GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i5-2320 CPU @ 3.00GHz (4C 3GHz, 3GHz IMC, 2x 256kB L2, 6MB L3) Socket/Slot : FC LGA1155 Chipset Memory Controller : ASRock Core (Sandy Bridge) DRAM Controller 100MHz, 2x 4GB DIMM DDR3 1.33GHz 128-bit Memory Module(s) Memory Module : Corsair CMX8GX3M2A1333C9 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Memory Module : Corsair CMX8GX3M2A1333C9 4GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-24 5-34-10-5) Video System Monitor/Panel : LG IPS237 (1920x1080, 23.1") Monitor/Panel : LG IPS237 (1920x1080, 23.1") Video Adapter : AMD Radeon HD 6800 Series (960 SM5.0 775MHz, 1GB DDR5 4GHz 256-bit, PCIe 2.00 x16) Video Adapter : AMD Radeon HD 6800 Series (960 SM5.0 775MHz, 1GB DDR5 4GHz 256-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : AMD Radeon HD 6800 Series (960SP 12C 775MHz, 1GB DDR5 4GHz 256-bit) Compute Shader Processor : AMD Radeon HD 6800 Series (960SP 775MHz, 1GB DDR5 4GHz 256-bit) Storage Devices SAMSUNG SSD 830 Series (256GB, SATA600, SSD) : 238GB (C:) (D:) WDC WD10EADS-11M2B2 (1TB, SATA300, 3.5", 32MB Cache) : 932GB (E:) Logical Storage Devices Samsung 830 (D:) : 160GB (NTFS) @ SAMSUNG SSD 830 Series (256GB, SATA600, SSD) James Hub (E:) : 932GB (NTFS) @ WDC WD10EADS-11M2B2 (1TB, SATA300, 3.5", 32MB Cache) Hard Disk (C:) : 78GB (NTFS) @ SAMSUNG SSD 830 Series (256GB, SATA600, SSD) Peripherals LPC Hub Controller 1 : ASRock H67 LPC Controller LPC Legacy Controller 1 : T0 C3-33 Audio Device : ASRock Cougar Point High Definition Audio Controller Audio Codec : Realtek Semi High Definition Audio Audio Device : PC Partner Radeon 68xx HDMI Audio (NI Barts) Audio Codec : ATI (AMD) HDMI Audio Serial Port(s) : 1 Disk Controller : ASRock Cougar Point 6 port SATA AHCI Controller USB Controller 1 : ASRock Cougar Point USB Enhanced Host Controller #2 USB Controller 2 : ASRock Cougar Point USB Enhanced Host Controller #1 USB Controller 3 : ASRock Etron USB 3.0 Extensible Host Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Wireless Adapter : 150Mbps Wireless 802.11b/g/n Nano USB Adapter (802.11g (ERP), AES-CCMP, 48Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1) Platform Compliance : x64 |
Have you done the system optimizations for PT?
Wireless adapter should be off. |
I personally would update windows upgrades first - fwiw
So will the system stay stable w/o creating tracks in the session ? - a full uninstall might be worth considering - so does the Focusrite play nice with windows? - do u have mix control loaded ? What version? - any device manager issues ? What kind of mobo was that ? - if I remember right LG1155's chipsets were kosher most everyone used the other ones (i7's?? I don't remember) but u could search the forum for ur chipset b/c a lot of people have put up useful info over the years - chipsets that worked w/o issue and other ones that did not
EDIT: doesn't work with wireless disabled and unplugged as well. Last edited by JamesClark1991; 11-14-2012 at 04:41 AM. Reason: .. |
Pro Tools loads to the "create a session" window most of the time (sometimes it crashes at loading bus 127-128) I've already tried uninstalling and re-installing once The reason I bought the Focusrite was because it was known to be good with Windows driver-wise. It plays back everything normally e.g. system sounds, WMP etc I'm sorry but I don't know what "mix control" is :L Just checked and there are 2 items with yellow alerts on the in Device Manager, "Ethernet Controller" which is probably because I didn't install the driver for it as I use a wireless adapter and ethernet is not needed. The other item is just "Unknown device" no idea what that is tbh. The mobo is ASROCK H67M-ITX |
Wow that's a new motherboard company never heard of those guys before
Did you build the system yourself? Pro tools is really finicky I'm not sure how much experience you've had before but even something as weird as missed matched ram (which you don't have) or a video card may cause problems
Yes I built the system myself, been running for almost a year and EVERYTHING works fine, games, programs, music, video all ports, stat interfaces etc. Just Pro Tools is clearly just an awful port on PC. |
Pro Tools SE Wont Load. | Jay_Enna | Pro Tools SE and Essential (Win) | 0 | 05-04-2011 02:39 PM |
pro tools wont load | matt.brack | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-25-2010 07:39 PM |
Help! Pro Tools wont load | Istarri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-07-2009 02:00 PM |
Pro tools 7.3.1 or 7.4 wont load | tah money | Pro Tools M-Powered (Win) | 3 | 08-14-2008 05:20 PM |
Pro Tools wont load | premonitionofmisery | Pro Tools M-Powered (Win) | 13 | 02-08-2007 12:03 PM |
