Old 06-29-2011, 10:12 PM
notrude55 notrude55 is offline
Default Loop playback not working since my 9.0.3 update
For some reason loop playback is giving me a Hard Drive error, can't get data fast enough, I'm on a westmare mac 8 core OSX10.6.7 PT9.0.3 BLA 002R, 3 HDDs one system, one media, one backup all 7200 rpm 47 track session not a lot of plugins in use yet and actually problem surfaced prior to any plugins being introduced. the highlighted section will play and just before the end it will stop and display the error message which also sites firewire problems. Anyone else experiencing this issue? Is it a bug in the update or am I the only one? Is there a fix? No I haven't trashed prefs or done any trouble shooting, been very busy and have had no time to trouble shoot.
Thanks for your help.
Mac Pro dual 4 core 2.4GHz Westmere, OSX 10.6.7 6 GB RAM, 1 TB boot HDD 500 DB Media Drive 2 500 GB backup drives BLA signature series Digi 002R PT9 full version, Digi/Magma updated 13 slot PCIe to PCIx expansion chassis, 4 UAD-1 cards 3 TC Powercore PCI, Command 8.
Old 06-30-2011, 07:51 AM
Repo Repo is offline
Default Re: Loop playback not working since my 9.0.3 update
What is your buffer set to? It might be quick and easy for you to bring it up and see if the errors stop.
Old 07-08-2011, 08:48 PM
changing the buffer makes no difference, however, I am accustomed to highlighting a region or segment thereof and creating the loop playback parameters this way, but I find now I have to select the loop parameters at top of edit window in the timeline, is this something new or is there a setting I missed somewhere in options or preferences? Im feel stupid now.
Old 07-10-2011, 03:48 PM
Any comments? Anyone experiencing problems with loop playback?
Old 10-02-2011, 07:39 PM
Joeb1469 Joeb1469 is offline
I am also unable to loop selection sometimes. Only when I am looping smaller selctions. However, Protools seems to think small is around less then 1 sec.
Does anyone know if there is a setting I can change to allow protools to loop smaller selection. I am looking to loop very very small selections. 15 ms or less in micro editing.
Old 10-02-2011, 08:03 PM
No, PT has a 500ms loop limit (it's in the manual).
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 10-02-2011, 10:34 PM
brickroadstudio brickroadstudio is offline
+1
Since .0.3 I too have been unable to loop playback.
Cant figure it out.
Old 10-03-2011, 02:46 AM
tamasdragon tamasdragon is offline
I've used loop playback today without a problem. But yesterday I had some hiccups with it. For me, closing and reopening pro tools solved the issues.
my blog:Tamas Dragon
Old 02-24-2012, 05:27 AM
mafiacondon
Guest
Posts: n/a
loop play not working for me today , first time i've had this issue , restarting PT has not resolved the issue
Old 02-24-2012, 09:40 PM
YYR123's Avatar
YYR123 YYR123 is offline
about 5 months late on that one my friend…..
Daniel
Loop Playback Not Working Nathan W. Pro Tools TDM Systems (Mac) 15 08-12-2021 10:49 AM
Loop playback not working? IVcrane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-25-2010 02:07 PM
Loop Record and Loop Playback will not engage? Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-28-2008 06:03 PM
Loop playback in PT LE d_matt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-04-2003 06:38 PM
