Order of plug-ins? (11R)
Hey guys,
I was wondering if anyone could please check out the order of the plug-ins in one of my PT sessions? Any suggestions? The pic should be here: Thanks, David
https://adornment.bandcamp.com/ https://andotherwonders.bandcamp.com/ http://gcsband.bandcamp.com Mac Mini (m1, 2020)// OS Monterey// Clarett +2Pre// Pro Tools Studio 2023.6.0 |
Re: Order of plug-ins? (11R)
Nothing wrong with the order, but you should consider putting the D-Verbs on aux tracks instead of the audio tracks. It's CPU-efficient, and will allow multiple tracks to share the reverbs, which in turn can sound more homogenic. For instance a hammond organ and a guitar amp sharing the same room can sound great. Some prefer the eq before the compressor. Some prefer the other way around. I've heard stellar mixes from both camps.
How does it sound to you?
The only thing that really raised an eyebrow to me was you vox chain. Personally, I would instantiate a 1 band eq, set to high pass filter around 90-120 to filter out any low end info before I compressed it all into the mix. Of course as mentioned I agree about the use of aux's for your time based fx like verb, dly, etc...
You also might get good results with more than one compressor on the track as well, each doing a little work, vs 1 doing it all. This becomes subjective quick though, its not like you are doing anything "wrong", just depends on what the track needs...
Lincoln Mitchell www.studiofifty.net Mac Pro 2.66 Ghz Quad, 10.6.6, 12GB Ram, PT9, Logic 9, Kontakt, East West, VSL, Waves, Sound Toys, IK Multimedia RME FF UC, Focusrite Octopre mkii, UA LA 610 mkii, MC Transport, Yamaha HS80M, Lauten, AKG, Sure, Blue |
Thank you guys so much for the suggestions. It's much appreciated. It sounds okay to me but I know little about mixing & using PT on an expert level.
PT Lover, could you please explain how to put the D-verb on an aux track? I have failed before trying to do this. Lincol1, I'll try putting the EQ above the compressor. If you guys wanted to hear the track, it's called "Elevated" & it's on the links in my signature. Thanks again, David
BTW - renaming busses is just a good way to work - it's not absolutely necessary. I think it's a pain to remember what "Bus 15-16" is.
Thanks PT Lover! Get any music gear?
Lincoln, I'm trying your suggestion out. I'm trying out your suggestion; right now, the input is at 0 dB, the filter is at 1, Freq is 105 Hz, Gain is at 0 dB, & type is at Peak. Sound good? Thanks again.
What sounds good is your attitude, you (like the rest of us) will learn a bunch like that. What I suggested is a very generic application that you will find the best results after much experimentation. Have fun...
Lol, no I didn't get any gear. I've specifically said that I don't want any gear. I think about gear the rest of the year.
From my iPhone using Tapatalk
Remember one of the most important things I learned is that there are no rules. Only guidelines. Whiles it's clear that you have gotten some excellent advice on this thread already, one thing you will also learn is what works for you. So while PT lover's excellent instructions on how to use a verb or delay through a send, you might come across a mix that works for you on an insert possibly or maybe not. Just remember there are no rules. Everyone has their own paint brush.
John Pro Tools 12.5 Macbook Pro & Windows 7 Ultimate 64 Bit |
Any deals on plug-ins with new PT 9 order/ | Pais_man | Pro Tools 9 | 0 | 02-22-2011 05:03 PM |
Amp Sims and order of EQ and plug-ins | Premo | Tips & Tricks | 5 | 03-02-2009 03:37 PM |
Mastering plug in order? | RUNDMOD4MUSIC | Tips & Tricks | 13 | 04-23-2005 10:49 AM |
What order should plug-ins go in? | George Siede | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-11-2005 11:13 AM |
What`s best order of plug ins | jeffinmarin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 01-02-2001 09:39 AM |
