Can Both The Digi 002 Rack & 003 Rack Be Used Together?
I currently own the Digi 002 Rack. I'm looking to purchase the Digi 003 Rack. I would like to know if both Rack Systems can be used together while working in ProTools? Thanks.
Re: Can Both The Digi 002 Rack & 003 Rack Be Used Together?
Short answer is no. Protools only works with one interface at a time. You can however use each on a separate computer and synch the two via MIDI. If you are looking to increase the number of simultaneous inputs, the more appropriate method is to get an ADAT based Micpre-A/D converter type device.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Keep in mind that Digi offers a trade-in price for upgrading your 002->003:
http://imsproav.com/main/search/DIGIDE99053873036.html
Eddie Sullivan Long Island Mac Tech http://long-island-mac-tech.com [email protected] 631 786 3924 Freelance Mac/Pro Tools tech for hire. Metro New York Area. |
Thanks Fellas.
Hello all,
Can more than one 003R be used together? 003R + 003 Control? I would think that a number of 003 could be on the same FW network? If you can not use (2) 003 at once on the same FW, this destroys my plans! But remember, never loose sight of Digi's marketing stragery! The answer I usually get is "NO, it can't be done!", . . . unless I buy the real Pro Tools gear at huge dollars. It is really differcult to build a medium channel count PT system EVEN with PT 8.x LE. later, billy |
AVID recently announced Protools HD Native which is a bit more affordable than the full blown PTHD TDM systems but still a considerably more expensive system after adding the I/O options.
Obsidian Dragon
I can live with 18 I/O but that count is at 48kHz correct?
Thanks, Billy
GrievousAngel Statesboro, USA |
you know I never thought of this, but, can the 002R or Mix be used in standalone mode and lightpiped to the 003 effectively increasing input count?
Again, you are much better off going with an 8 channel ADAT based MicPre and A/D converter unit like a Presonus DigiMax FS. You are over thinking the problem and making it harder than it should be.
Obsidian Dragon
Yea the 002c will route the incoming audio to the adat out pre-fader in standalone mode.
Done this with 002c to 002r through the adat. However, since its prefader its only passing signal. Still need pres on ch 5-8.
Mac Pro, Snow PT 10HD,Sequoia, Reaper W7/64, PT 9HD,Sequoia, Reaper 192 HD, HD-N, 002C BLA, BLA AGB,Autuer,Lucid, MicroCLock, Pultec, UA, Sebatron, Focusrite, Trident,API, A-Designs, Purple Audio
Connecting Eleven Rack to Digi 002 Rack | TMitchJobe | Eleven Rack | 12 | 02-02-2013 10:54 AM |
Major comp. problem - considering reverting to 002 rack instead 003 rack, good move? | Tbassist4 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-15-2009 04:20 PM |
Rack Mount Ears for Digi 003 Rack | Flux06 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-28-2008 02:49 PM |
digi rack 003 rack spaces | keepeatingcars | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-06-2007 02:28 AM |
Digi 002 Rack or Factory Rack? | liquid32 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 07-08-2005 02:43 AM |
