Old 07-22-2019, 11:37 AM
clausiii's Avatar
clausiii clausiii is offline
Default Little utility to delete session backups (Mac)
Hi there!
I made an Automator app which searches for session file backups on your Mac and moves them to trash.
Before the app does this you can choose which backups you want to move to trash and which you want to keep.
The application searches for ".bak." and ".ptx" in the filename so be sure you have NOT ".bak." in a regular session name
I tested it on my system and it worked. Since this is an Automator application you can easily edit it in Automator and tweak the settings to your own preferences (like searching only on the session hard drive for example).
If you're interested you can download it from here.
https://drive.google.com/file/d/19K5...ew?usp=sharing
Use it at your own risk, I´m not responsible if something wrong happens on your systems.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 07-23-2019, 08:58 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Little utility to delete session backups (Mac)
Not trying to be rude, but why would you delete your backups? Just to save hard drive space?
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 07-23-2019, 09:34 PM
arche3's Avatar
arche3 arche3 is offline
it's a time travel post from 1989. When a 1 gig hard drive cost 1k.
Sent from my SM-G975U using Tapatalk
Old 07-24-2019, 11:41 PM
clausiii's Avatar
Yes. I found 5GB of session file backups on my HD.
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 07-24-2019, 11:42 PM
clausiii's Avatar
You don‘t delete unnecessary files on your HD, do you?
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 07-25-2019, 06:35 AM
arche3's Avatar
I don't delete any files from any protools sessions.
Old 07-25-2019, 11:34 AM
amagras amagras is offline
I can't count the amount of times the backup folder has saved me, I have it configured to store as many saves as possible in the shorter interval of time. I often clean up old audio files but not backups.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 07-25-2019, 12:21 PM
clausiii's Avatar
Yeah, i use backups too, that‘s not the point. If i wouldn’t want them, i would deactivate this function in the preferences.
It’s just a cleaning utility, nothing more.
I don’t say that it’s brilliant, i just found it useful and i don’t force anybody to use it.
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 07-26-2019, 03:15 AM
5 gig really isn't all that much and if you have to do what your utility is doing because you need the space then you really should have a bigger drive to begin with.
Jack
QAPLA!
Old 07-26-2019, 04:30 AM
clausiii's Avatar
well, again, it´s up to you if you use it or not and I don't care how you manage your sessions and hard drives. And I´m pretty sure you don't care how I manage mine. So there's really no need suggesting what I should do when there is no need for help. I don't delete backups every week/day/hour. At some point there's just no need for having some old session file backups (for me). And I like it getting a list of all the backup files where I select the ones i don't need. That's it. If this is no utility for you, fine. Maybe someone else finds it useful and I just thought that's something to share with the community.
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Recover corrupt session (session backups or importing session data not working) ejsalling Pro Tools 2018 5 04-28-2021 03:54 PM
Lost all plugins after using Tech Support Utility to delete prefs & databases Kevbasskeys RTAS & TDM Plug-ins 4 07-09-2014 12:40 PM
Can someone point me to the place to download the utility to delete all PT Settings? Violet Windows 3 07-27-2011 04:06 PM
Session Backups to DVD Tmando 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-10-2008 06:05 PM
Session backups shameeta General Discussion 2 12-21-2003 04:02 PM
