Old 12-21-2016, 03:33 PM
Brian in Charlotte Brian in Charlotte is offline
Default 12.7 Install = Assertion
Folks, I hope I have the correct place for this. Just downloaded 12.7 on my iMac 5k with 10.12.1 Sierra: When launching, I get this error. Any idea how to correct it?
Need any additional info?
Assertion in "/Volumes/Development/194038/ProTools/NewFileLibs/FF/Audio/FF_AudioFile.cpp", line 1100
The Voice of Brian
Mac Studio M1 Max, Focusrite Clarett2Pre, Sennheiser 416, sometimes Beta Tester for iZotope
Old 12-21-2016, 03:54 PM
grayter1 grayter1 is offline
Default Re: 12.7 Install = Assertion
I'm running 10.12.2 and so far, 12.7 is running without a problem. It's only been 10 minutes, but so far, so good...
tg
Mac Studio (2022) M1 MAX / 64GB / 2TB HD / macOS Ventura 13.6.5 / RME BabyFace Pro FS / SSL UF8 + UF1 + UC1 / Roland SYSTEM 8 / Kontrol S61 mk3 / Pro Tools Studio 2024.3 / Nuendo 13 / Reaper 7 / Komplete 14 / Omnisphere / Keyscape / Trilian / V Collection X
Old 12-21-2016, 04:03 PM
Well it's been a smooth "start" if nothing else!! I checked other sessions and they open fine, so something must have happened when I opened the initial session. Thankfully I didn't need it and was able to trash it. So far all others are working as they should. Thanks for the reply and hope your upcoming holiday weekend is great for you and your family!
The Voice of Brian
Old 12-21-2016, 04:20 PM
Thank you, and happy holidays to you as well...
tg
Old 12-21-2016, 04:21 PM
TOM@METRO's Avatar
Here on Windows, Pace has been totally corrupted with this install. I had to go back to an earlier drive image.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 12-22-2016, 01:02 PM
I COULD STRANGLE AVID........can't work at all. When I open any of the sessions, I get ASSERTION.......line 1100. I need help FAST.
The Voice of Brian
Old 12-22-2016, 01:25 PM
I tried from my account on the site, not the Application Manager. I even tried to move back to 12.6.1 but it defaults to 12.7. I'm sure there is a way to do it, but I don't know, unless perhaps I trash the Application on my Mac and try it.
The Voice of Brian
Old 12-22-2016, 01:42 PM
I put the Application in the trash, then re-installed 12.7 but same issue. Unless I start a new session, I'm dead in the water.
Can't find answers anywhere and my clients are on hold till I get it sorted.
"Could not complete your request because Assertion in "/VolumesDevelopment/194038/ProTools/NewFileLibs/FF/Audio/FF_AudioFile.cpp", line 1100
The Voice of Brian
Old 12-22-2016, 01:54 PM
MAYBE made some headway here...I truly hope this helps someone. After doing much reading etc., I finally found something on Sweetwater that may have helped:
"In Pro Tools 9 and up, try changing your Playback Engine. This can be done from the Setup menu > Playback Engine. If the Assertion error is preventing Pro Tools from opening, try holding the “N” key on your keyboard while Pro Tools boots up. This will force the Playback Engine dialogue to open before Pro Tools initializes the engine. If the Assertion error disappears, your last session was likely corrupted. "
I tried this and when PT booted up (while I held "N") the dialogue box appeared and sure enough the Playback Engine was on ProTools Aggregate and not my Focusrite. I changed it to my interface and the session opened fine. I just imported session data from the bad try and I'm back. WHEW
The Voice of Brian
Old 12-22-2016, 02:32 PM
jeffro's Avatar
jeffro jeffro is offline
Sorry you're having trouble but glad to hear you're making progress. Searching for assertion in the KB leads to this. Trashing prefs and changing the Playback Engine typically resolve it.
linkedin
Install PTHD 8.1.1 udater on Win7x64 and says valid install not found 8.0.3 is there rnygren Pro Tools TDM Systems (Win) 2 10-25-2014 10:58 PM
Pro Tools 10.3.2 wont even install! After clean windows 7 install!!! shamanrock Windows 13 12-27-2012 04:39 PM
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions b-pole macOS 2 08-31-2011 07:23 AM
Can't install Pro Tools 8! Clean install, new system, Vista! DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 31 01-09-2011 11:16 AM
Can't install Pro Tools LE - Insert disc but no option to install Paul McConnell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-22-2010 08:13 AM
