Where is ProTools heading?
I'm a Digi003 user on a MacPro with 13gb RAM.
I have been dreaming of a PTHD upgrade for years, but should I just hang tight? Using and HDX card sounds great, but if PT 11 is 64-bit, couldn't I save a huge chunk of change by buying HD/Native and allowing my CPU to RAM cache and finally take advantage of the RAM I have to help with DSP? I want PTHD for the higher clarity, fidelity and IO flexibilty. Should I blow 12K and get HDX, or blow slightly less and get HD/Native? PS., in either case I hope to use HD OMNI from Avid.
ProTools 10 / Digi003 Control Surface / MacPro 8-Core (2, 3GHz Quad Intel Xeon) / 13GB RAM / Snow Leopard / Reason 5 & Record / Superior Drummer |
Re: Where is ProTools heading?
Aaaaah the eternal dilemma. Seriously I completely understand your frustration. The answer is, I am afraid, not simple...well depends on the perspective really. There are applications for which investing into an HDX rig is straight out and Native is the way to go. Then there is the other side. Now personally I was confronted with the same dilemma and I have decided to go HDX...well HDX2 in fact because of:
Greater flexibility in the future (I am free to choose DSP and Native PIs) Greater voice counts (especially in higher kHz) Greater CPU off load (similar to point #1 but not identical) Lower latency Hope that AAX-DSP will come (sentimental, but hope dies last...still I am feeling things are headed in the right direction) Various other reasons Now it all depends on your needs and expectations. And budget. I had the luxury of investing into an HDX2 system and I do not regret it. This however still does not mean I need it. Do I? Well...that is another story for another day.
********** Main DAW: MacPRO 7.1, 16-Core Xeon 3.2GHz, 196 GB RAM, OSX 10.15.2, HDX3, PT 2019.12 Ultimate, 2x UAD-2 PCIe Octo's, Raven MTZ, 1x HD Omni, 2x HD I/O's, 1x MTRX and some more cool stuff... Auxilary DAW: MacBook Pro with Retina Display (2012), 2.6GHz quad-core Intel Core i7, 16GB RAM, OSX 10.13.6, PT2019 Ultimate, 1x UAD Apollo Quad Audio Interface /w Thunderbolt Interface (v9.x) ********** |
I have an HD3 system and where that maxes out incl. the use of TDM Plugs this where my MacBook Pro Retina 2.6 GHZ barely reaches 30% == Just for fun I opened a really intensive Protools TDM HD3 project on the Retina... As I said, 30% and the MacPro 16 Core 2.26 Nehalem with TDM HD3 maxed out... Just for giggles I added a 30 Inch Cinema Display to one of the thunderbold ports while PT was playing the mentioned session... The I opened Final Cut X and start doing some VERY intensive Color Grading (Full Screen on the 30 Inch) /// No hickups no nothing. I was so blown away that I immediately made the Retina my main Studio Computer.... The TDM system has been sitting in the shade ever since and I am selling it. Protools Software is second to none the hardware is third to many. Surely there are situations where some folks would need 3 HDx cards but I stronly doubt that ONE HDx card in a normal nehalem Mac Pro could ever achieve what the MacBook Pro Retina does.... Good Luck PS - The Apollo PreAmps are very very Good and so are the converters. Lots of choices today and that is great ;-)
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10 |
Avoid the Retina like the plague. It is not a "Pro" machine by any rate. Can't do any upgrades yourself, the screen resolution is not supported by much of anything (which means a lot of static plugin windows will look painfully small), and everything is basically glued together (the battery, in particular). Get the full sized Macbook Pro. Has far more I/O options, and you can swap out the optical drive and put a REAL SSD in it. OSX on the SSD and everything else on the 7200RPM drive. NOW you have a Pro laptop for audio production. The Retina is just glitz and glam. Quote:
Besides, comparing any Mac Pro to any Ivy Bridge chipset computer is not a fair comparision. Mac Pros are dated and a waste of money. Of course a Retina will outdo it in terms of power, but so will most other modern i7s. The Retina isn't as impressive as you think. Just about any laptop with an i7 and an SSD should perform just as well.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
@Dan,
'MacPro a waste of money'?? I can certainly see why you think them over priced, but alas, that's Apple for ya. I have had my Pro for a few years now and PT hasn't faltered but a handful of times. That said, I couldn't imagine making a MacBook Pro or ANY laptop for that matter running long (HOT) hours upon hours sessions. Many moons ago I used a laptop...under powered, granted, but it was uuuugggly. I have a PC running i7 chipset, but my Mac Pro still kicks some tail....for now...
Professional means that you make a living with it... Nothing else... Think you have been a little indoctrinated by all the apps with a |PRO| word to them ))))) Quote:
Never thought it would be / bought for mobile Film Editing. It is the first time in history that I can do everything on a laptop... Edit RAW video... no Problem Playback 60 Tracks 96KHZ in Protools... No problem and that with a plug on each channel. Oh... Did I mention that BOTH ABOVE are done from the System SSD Drive.. Sure... The parts are glued together... But 16 GB of RAM and 768 GB SSD will get you along way along with 2 USB3 and 2 Thunderbolt... Latter you can even get an PCIe expansion for and run HDX should you need more than 100 Tracks of audio with plugs on each channel.... Some folks need more than others... I know this, my retina smokes my HD3 system by FAR I can run about 4 times the amount of effects on the retina in comparison. And I can carry it all in a small lap top bag.... You should TRY the Retina before judging it....
I mean buying a Mac Pro brand new right now is a waste of money, because the technology is already 3 years old. A $1000 Ivy Bridge i7 PC will run circles around a current Mac Pro. A Retina Macbook Pro also outspecs most Mac Pros.
The thing is, I USED to be indoctrinated by Apple's "Pro" line, but not so much anymore. They did away with a lot of the things that made them Pro. Notice how they stopped selling regular Macbooks? They all have the "Pro" moniker now. This suggests to me that anyone can be a "Pro" just by buying a laptop. The Pro line used to be a real step up. Now it's just the basic consumer line. I'll take my Hack over any current Mac right now. For the $2500+ you spent on a Retina Macbook, I could have built two of my current tower, and it doesn't need a breakout cable for ethernet and firewire. Also, it's a bad idea to do all your reading and writing to a single SSD. It will die fast. I have 4 drives in my tower for a reason. Just my O.
you could buy almost three retinas for the price of 1 worthy Mac Pro and with VE PRO that would smoke the Mac Pro and any HDx... Plug/in Wise... an HDx is like 7 big ones. And it will run LESS instantiations of plugs than a Retina via VE PRO. You could buy 3 retinas for the price of ONE HDx and still run MUCH more DPS processing. Plus you would have 3 great displays too ;-))))) This option will be MUUUUCH more viable for anyone working with VIs.. And a lot cheaper to... Of course if you need to mix a 292 track Avatar Feature Film an HDx is probably what you need. Quote:
Dan - what is ur mobo and CPU model and specs ???
It sounds like a nice setup
Question about where Avid is heading | sw0mgt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-16-2012 01:01 PM |
SELFLESS PROMOTION---heading to China for the WORLD CHOIR GAMES! | BradLyons | General Discussion | 0 | 05-02-2010 06:00 AM |
Heading back to PC from the Mac... not quite sure yet. | silversunpro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 05-02-2007 05:40 AM |
What are the parentheses under replies heading? | klwilbur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-19-2004 04:52 PM |
Am I heading in the right direction ? | Steve Nelson | Pro Tools TDM Systems (Mac) | 4 | 10-27-2003 06:40 AM |
