Old 01-19-2019, 09:20 AM
thefinallap thefinallap is offline
Default ProTools not optimized for your Mac warning
Despite not being supported, ProTools 2018.10.0 works flawlessly on my new generation MacMini. (I had no choice with Mojave)
That said, I occasionally get the "ProTools not optimized for your Mac warning" so something is not fully 64 bit. Is it a plugin, the main app, helper app?
Thoughts
Kerry
ProTools 2018.10.0
MacMini i7
Old 01-19-2019, 12:15 PM
Default Re: ProTools not optimized for your Mac warning
Thoughts
Kerry
ProTools 2018.10.0
MacMini i7
It's not PT causing the warning. It could be a plugin that's not 64 bit (what plugins are you running?). Move all 3rd party plugins to the unused plugins folder when PT isn't running and restart PT. You could have a problem if you have something on your machine that requires Rosetta and that hasn't been supported in OSX for quite a while.
Jack
QAPLA!
Old 01-19-2019, 01:29 PM
Question Re: ProTools not optimized for your Mac warning
This is not the case. Pro Tools Plug-In Compatibility Grid states Pro Tools 12 and above require plug-ins to be AAX format and 64-bit.
If you:
  1. Switch to Finder
  2. Press Command+Shift+U
  3. Launch Activity Monitor
Do you see any processes whose Kind is listed as 32 bit? You may have to add the Kind column to the view.
Old 01-19-2019, 02:14 PM
If you:
  1. Switch to Finder
I know what the grid says. That doesn't mean a 32 bit plugin can't be installed; it would go in the same folder as aax64 plugins.
Jack
QAPLA!
Old 01-29-2019, 05:19 PM
Oliver M Oliver M is online now
You are wrong. It is PT causing the warning, an old 32 Bit component that is.
Old 01-30-2019, 06:06 AM
And you know that how? PT2018 is 64 bit and doesn't have 32 bit code.
Jack
QAPLA!
Old 01-30-2019, 06:36 AM
EdwardWilliam's Avatar
EdwardWilliam EdwardWilliam is offline
I’m running the latest PT version on Mojave with almost no problems. And almost every time I start my new Mac Mini, I get a 32 bit warning window for a piece of software that I can’t readily identify, and the warnings state that future versions of Mac OS will not support this 32 bit program. Guess I should start making a list of them.
Love running my x8p with my new Mini, 64 GB of ram.
Thanks for the Activity Monitor tip.
Edward
Old 01-30-2019, 07:57 AM
AlexLakis AlexLakis is offline
I got this error for seemingly no reason a few days ago. Nothing had changed in my setup, so I was surprised. Everything works fine, tho. Latest Mojave, latest Mac Mini, Pro Tools 12.6.
Old 01-30-2019, 09:28 AM
BScout BScout is offline
Open Activity Monitor
Show "kind" column
Sort by "kind" column to find 32 bit apps.
Old 01-31-2019, 06:01 AM
skippy skippy is offline
Hi, just getting back into audio & video. My 2008 MacPro died recently and decided to get the i7 Mac Mini, running OSX 10.14.2, did a PT9 to PT 2018.12 upgrade, all fired up and working well.
Warning Message From ProTools M-Powered Essential 8 Aditya86 Pro Tools SE and Essential (Win) 2 05-13-2011 05:10 PM
Protools 7.2 warning ! Stjernholm Pro Tools TDM Systems (Mac) 3 08-14-2006 01:15 PM
Protools quits with no warning Gio Mix Pro Tools TDM Systems (Mac) 4 12-18-2003 09:16 AM
is Protools LE 5.0.1 optimized for the g4? The General Lee 001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-14-2000 09:47 AM
16-bit v 24-bit Optimized Mixer David Wright Tips & Tricks 1 08-16-2000 11:09 AM
