Old 06-04-2017, 06:29 PM
audioman1973 audioman1973 is offline
Default Group Volume Edits With Clip Gain
Searched high and low in user guide and keyboard shortcuts guide and haven't run across the answer to this one yet. Hoping someone can help me.
Say I have for instance all the drum tracks in a song already grouped together. I then do a selection of audio and use the separate at selection command which creates a new clip up and down all the tracks in my group. Now here's the question. What is the keyboard command to raise or lower clip gain volume on all tracks in the group simultaneously? So far I have had to adjust the volume on each individual track in the group which is very time consuming. There must be a way to raise or lower clip gain volume on all tracks in a group together. Thanks.
Pro Tools Ultimate 2023.9. Mac Studio M2 128GB Ram 24 Cores 4 TB HDD. 2 Universal Audio Satellites. Lynx Aurora N.
Old 06-05-2017, 06:41 AM
SIGA.studio's Avatar
SIGA.studio SIGA.studio is offline
Default Re: Group Volume Edits With Clip Gain
I was looking for ilthe same feature but it seems it s not available in protools...by the way it s available in cubase
Sent from my SM-A510F using Tapatalk
Old 06-05-2017, 07:28 AM
Thanks for your reply. Hard to believe Protools wouldn't have that. It would save a lot of time.
Old 06-05-2017, 07:35 AM
joachim's Avatar
joachim joachim is offline
Nudge the selected clip gain up : Control+Shift+Up Arrow/Start+Shift+Up Arrow
Nudge the selected clip gain down : Control+Shift+Down Arrow/Start+Shift+Down Arrow
Or Start Shift Scrollwheel.
Works perfectly on edit-grouped tracks and their clips in PT 11 at least.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 06-05-2017, 07:50 AM
Thanks Joachim I'll give it a try. Do you know if it works is as small increments as 0.1 db?
Old 06-05-2017, 07:51 AM
joachim's Avatar
If you set 0.1 dB in Preferences - Editing - Clip Gain Nudge Value.
Or : select clips in the edit-grouped tracks , show the Clip Gain Line and adjust with mouse up/down while holding Ctrl (Win) (should be Cmd Mac). This the fine-control.
Old 06-05-2017, 11:08 AM
Thanks very much.
Group clip gain adjustment problem Ke productions macOS 28 04-08-2015 06:29 AM
Include Clip Gain edits in groups? Ticker Pro Tools 11 6 09-19-2014 05:20 PM
change clip volume for a entire group Talisker Pro Tools 10 2 03-13-2013 08:33 AM
Clip Gain doesn't follow trim edits bug? JR Fountain Post - Surround - Video 0 02-17-2012 06:28 AM
Converting Volume Automation to Clip Gain = Higher Volume! EricWillhelm Pro Tools 10 8 11-01-2011 11:12 AM
