PT12 sluggish and unresponsive on Windows
Got it all installed on a brand new win 7 load and upon running it takes 2-3 minutes to load to the file open screen, click on a protools session to open (small one 12 tracks) and maybe 3-5 minutes later I will finally get a screen of tracks. Press play and I get an error message that I am out of CPU and to reduce the plug ins, there are none and the load meter shows NO cpu load, no memory load and a tiny amount of disk load.
There are no floppy drives installed or enabled, there are no usb drives or externat drives of any sort plugged in and there is no cd in the drive. I scanned the threads and found that suggestion. The system acts just as everyone else describes their system before removing the cd in the drive or usb stick. If you click on any menu item the top bar immeadiately changes to (not responding) next to the window title and you lose control of the window for a minute or two and then it comes back. This is repeatable and never changes. I loaded up a couple other drives with fresh loads of Win8.1 and win10 preview build 10074, Same results so I know it's either hardware related or PT12 related and likely not an OS issue. I welcome any ideas. FYI: versions 10 and 11 work fine and fast.
Working for the preservation of quality live sound.... One show at a time! Work Twin S6L's PM-10 Profile, D-Show 3 Midas Heritage's and 5 M32's Several other analog and digital consoles d&b J Systems L'Acoustics V-Dosc systems Home: Compaq Z800 Dual XEON hexes 48G Ram Windows 10 Midas M32 and XL48 Genelec 8050's with Genny sub Genelec 8030's JBL L96 & LSR32 |
I can't offer a solution, only empathy. I spent a couple of weeks doing a back and forth with an Avid tech (who was very patient and intelligent, to be fair) using my sparkly new Support Option to troubleshoot the exact same issue(s).
At which point I had requested a refund to find out that since I purchased it prior to the end of last year (to beat the ticking clock; even though I hadn't activated the asset to an iLok until 12 dropped into my account), a refund could not be authorized. Add that to the genius strategy of not being able to transfer a subscription license and I've got a $199 bad taste in my mouth. Peachy. Where's that form on the Better Business Bureau site again? |
Make sure your graphics driver is up to date.
If this is a freshly built machine, make sure your bios is the latest version.
Protools 10.3.10/11.3.2/12.6 | Win 7 Ultimate 64 bit |
i've seen this exact problem - it's a conflict with your audio driver.
If that doesn't help, try setting PT to run in Compatibility mode:
http://www.avid.com/Support/Contact/audio-support > Pro Tools...
• linkedin •
• linkedin •
Had the same issue
Jeffro's KB article fixed it for me. The command prompt entry specifically was the fix. The problem occurred when I uninstalled a demo of BFD3.
Every time I install PT12 on Windows (3 times now) I get this same problem at first
Everything takes forever, PT hangs constantly, and everything is full of errors Every time, the problem was because PT had selected the motherboard Realtek audio device, or because my audio interface buffer size was incompatible with PT. Start by setting your interface buffer size (in the interface settings, not in PT) to 1024 samples. Then open PT, do not open or create a session, go straight to options -> playback engine and ensure your interface is selected there. Then close PT down and restart it, and confirm that these settings are still selected when you open it. If you're still seeing your interface and a 1024 buffer then you should be good to go. You will probably want to reduce your buffer from here, to do so *close down PT first* then open interface settings, adjust buffer, then re-open PT and confirm the change in options -> playback engine. Again... every time I have installed PT 12 I've seen these problems, and they were down to these two things every time. |
The new "Windows Audio Device" "Playback Engine" in PT 12 may be causing your problems. Since PT cannot set its sample rate, you either need to set it to whatever was used the last time PT ran, or create a new session. Either way you have to set the rate (and bit depth) appropriately via Window's "Playback" "Recording" and "devices" advanced options. Also, you need to do this before starting PT and with all of your other audio devices ("interfaces") off or disconnected.
I feel your pain - good luck! Quote:
PT12 and PT12 HD surround? | theom | Pro Tools 12 | 17 | 10-12-2015 09:27 AM |
Toggle Mix and Edit windows shortcut bug in PT12? | emj_antonin | Pro Tools 12 | 1 | 05-15-2015 05:18 PM |
Upgrading from Windows 7 to 8 with PT12 | bzerk | Pro Tools 12 | 0 | 04-24-2015 01:17 AM |
PT11 sluggish on Windows 7 | YYR123 | Pro Tools 11 | 15 | 07-22-2013 01:16 AM |
Sluggish unresponsive scrub | simonchase | Pro Tools TDM Systems (Mac) | 11 | 06-14-2010 12:03 AM |
