Old 11-07-2017, 07:58 AM
Macsearcher Macsearcher is offline
Default layouts strange behavior
Hey Eddie.
I generally use two layouts and switch back and forth between them.
Layout A has my VCA's and layout B is default which simply has everything set to auto-choose.
When I select layout A, the S3 populates the far left fader with track 12 no matter where I had previously selected.
Start a new session and create 40 tracks or so.
Attention track 20 - the S3 spills 20-35 - so far so good
Select layout 1 from the S3 (named default in this case) - S3 spills 12-27 -not good
Attention track 6 - S3 spills 6-21
Enable layout 1 - S3 spills 12-27
if a add more tracks to the session, the layout simply replaces the default starting track with whatever falls into the 12th slot.
EDIT *****
I've been doing some more testing and found the following.
The track that is selected at the time that a layout is created will become the default TRACK in the auto-assign layout.
So.
1. Create 30 blank tracks.
2. Select track 1
3. Create a layout called Layout A and leave all slots blank (auto-assign)
4. Save layout
5. go back to PT and select track 10
6. created a second layout called Layout B and leave all slots blank (auto-assign)
7. Save layout
now when you select layout A from the S3 it will populate with 1-16
when you select layout B it will populate with 10-26
The behavior is identical on Eucontrol 3.61 and 3.7
Please help,
Thanks
Old 11-07-2017, 09:51 AM
Default Re: layouts strange behavior
Old 11-08-2017, 08:25 AM
EddieJones's Avatar
I'll take a look on Monday when I'm in front of an S3.
Old 11-13-2017, 05:51 PM
Hey Eddie,
Just wondering if you've had a second to look at this.
Thanks
Old 11-14-2017, 10:00 AM
EddieJones's Avatar
I think this is working as expected. When you save Layout A you are saving tracks 1-16, when you save Layout B you have selected track 10 (and I presume you have bank to selected on) so you are saving tracks 10-26
Old 11-14-2017, 12:27 PM
Ah, I understand.
Is there any way to suspend layouts or make some kind of a zero layout default?
It would be handy and make a lot of sense for when you are mixing and you want to jump to a layout, say VCA's, adjust some levels and then pop back to where you were in the session, ie, selected track.
Old 11-14-2017, 12:46 PM
EddieJones's Avatar
Unfortunately not I think.
8.0.1 Strange behavior?!?!?!?!?! danander11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 25 09-03-2009 03:44 PM
7.3 strange behavior donicas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-17-2008 02:22 PM
Strange Behavior Bender 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-16-2007 04:19 AM
FB strange behavior Branko Post - Surround - Video 2 11-26-2006 04:35 PM
Strange 002 behavior Ricco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-25-2003 06:45 AM
