Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
Old 02-22-2017, 04:38 PM
ChrisMac ChrisMac is offline
Default "You are trying to run a newer version of Pro Tools than allowed" error launching PT
Was running 12.7 all day and decided to upgrade to 12.7.1, now I get this message on launch
"you are trying to run a newer version of Pro Tools than allowed by your license"
Now I can't run Pro Tools, help
Chris McIntosh
President/Sound Supervisor
Postal Audio Inc.
Imdb
Facebook
Old 02-22-2017, 04:39 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Upgraded to 12.7.1 and now license not allowed
Will check it out...
linkedin
Old 02-22-2017, 04:51 PM
jeffro's Avatar
Started a support case for you, but you should be able to Sync your iLok and get back to work. Please look for a case notice email and reply to that if needed. Thanks!
More info
linkedin
Old 02-22-2017, 10:12 PM
Rockmixer 67 Rockmixer 67 is offline
I have the same issue, see ilok lic and update plan there. Been using 12.7 all day then upgrade to 12.7.1 and no go
Old 02-23-2017, 10:48 AM
jeffro's Avatar
Welcome to the community.
Checked your license and that looks correct. Can you please try the steps listed here and report back?
linkedin
Old 02-23-2017, 11:36 AM
mastermixaudiomedia mastermixaudiomedia is offline
Default Re: "You are trying to run a newer version of Pro Tools than allowed..." with PT 12.7
I'm getting the same behavior even after performing the procedure detailed above.
Back to 12.7 for now...
Old 02-23-2017, 01:42 PM
DigiTechSupt's Avatar
License seems to be okay on your iLok account. Please try the following:
  1. Uninstall Lok License Manager, then install the current version from ilok.com/#!license-manager
  2. Restart your computer
  3. Launch iLok License Manager and Sign In
  4. Sync your iLok (right click on the specific iLok and select "Synchronize")
  5. In some cases it might be necessary to go to the iLok License Manager menu > Preferences > Licenses tab and click "Remove account data saved on computer" then click "Apply" then "OK" and Synchronize again
Let us know if the same issue occurs.
Thanks,
TD
Avid Audio Tech Support
Support FAQ
Old 02-25-2017, 04:27 PM
misterwine misterwine is offline
Has this worked?
Old 02-25-2017, 06:08 PM
This is not working I have tried several times and i get no results same message, it really pisses me off that stuff like this happens on updates, come on Avid fix it I really am disappointed that we need to go through this over and over.
Old 02-26-2017, 07:12 AM
Default update to version 12.7.1 and error newer version than allowed
I just did my update to version 12.7.1 and I get the following error message when I try to launch Pro Tools:
"You are trying to run a newer version of Pro Tools than allowed by your license...(etc)"
I tried all the solutions posted , Ilok reinstalled re linked etc, tried reinstalling pro tools no go.
Frustrating everything was fine on 12.7 and no response from Avid as usual.
Anyone got suggestions for a fix?
Pro Tools 10 won't open session file (Created on a newer version) sjafarzadeh Pro Tools 10 8 06-14-2023 11:24 AM
This session file was created by a newer version of Pro Tools [7.4.2f109] olivergodfrey Pro Tools M-Powered (Mac) 3 02-12-2013 04:53 AM
unable to install bfd lite for pro tools 8 beacause newer version already exists? Digitopian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 04-25-2009 12:00 PM
