003, unable to set 96 kHz sample rate
Pro Tools 2019.6
003 Console Win 10 Home version 1809 Was working on 96 kHz 32-bit-float session last week; but now session opens as 44.1 kHz, and additionally, unable to set 96 kHz sample rate in create new sessions, or in hardware settings... the selection is initially allowed, but then the error message: Getting error message: "The current playback engine doesn't support 96 kHz sample rate" Playback Engine in Pro Tools *is* the 003; And, as is best practice in Windows, the default audio device is *not* set to 003 (this is what usually generates this error) |
Re: 003, unable to set 96 kHz sample rate
Moderator: Please move to:
Got it !
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
1-Windows is using the 003(please double-check the Windows sound settings as updates for Windows, or for hardware drivers can often reset that(windows updates also like to reset USB Power Management) 2-you have multiple devices connected digitally to the 003 and clocking is locking to a piece that is set to 44.1K. If this is no help, come back with lots of details on ALL hardware connected
Ok... I must have overlooked something, browser open, or some other application;
When I ensure nothing else is running (and as always confirm Win default audio device set *away* from 003), the issue disappears, and all returns to normal. |
I know in my setup with 003 console, I have to make sure that in the Windows Sound Setting, all of the playback devices are disabled before I open PT ... sometimes I have to disable and reboot. This is a workaround and it sucks, but it solves the problems
Hopefully an easy one for you guys: Opening 8 KHz sample rate / 16 bit sample size | sample | Pro Tools 11 | 2 | 02-24-2016 01:04 PM |
Unable to change sample rate or buffer size with 11R | MattBaron | Eleven Rack | 5 | 03-05-2012 03:39 PM |
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up | finalcut | Windows | 12 | 02-20-2012 04:00 AM |
MBox Micro Sample Max Sample Rate Only 48 kHz? | Joe Sciacca | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-07-2008 12:52 PM |
Bit Rate/Sample Rate problem? The chipmunks? | bspro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-17-2008 05:40 PM |
