  #21
Old 12-21-2014, 10:15 AM
CygnusX-1Bk2 CygnusX-1Bk2 is offline
Default Re: 11.1.3 -9173 every time you insert a 3rd party plug question.
The -9173 Real Time Bounce error has been addressed with 11.3. I could not Real Time Bounce @ 96k with 11.2, 11.2.1 or 11.2.2 but with 11.3 mixes that would not bounce with 11.2.x are fine now. At least for me.
I will choose,
Freewill
http://jimdiazaudio.com/
  #22
Old 12-21-2014, 03:58 PM
jryser's Avatar
jryser jryser is offline
+1 Cygnus!
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
  #23
Old 04-15-2015, 02:05 PM
jcirrone jcirrone is offline
no matter if i had plugins or at whatever configuration i could no longer do a real time bounce. i like to tweek it even w/Automation it's like adding sprinkles. I TRIED it the other day & it now seems to be working. Anyone else? How ifits fixed didAvid fix it withoutan update? Did they tweek the original 11.3 ? i hope i didn't just had a fluke or we all had defender on
Thanks for your time
kind regards J.C.
  #24
Old 04-15-2015, 02:21 PM
Originally Posted by jcirrone View Post
No matter if I had plugins or at whatever configuration I could no longer do a real time bounce. I like to tweak it even w/Automation it's like adding sprinkles. I TRIED it the other day & it now seems to be working. Anyone else? How if it's fixed did Avid fix it without an update? Did they tweak the original 11.3? I hope I didn't just had a fluke or we all had defender on.
kind regards J.C.
Well the latest version of PT11 is 11.3.1 so yeah - there's an update to what you may have. But then again we have no idea of what's in your system and how it's set up; there might be something in that that is causing your problems. Proper configuration goes a long way to smoothing PT issues.
And you really shouldn't be running any kind of antivirus when running PT. THAT might well be the problem with your setup.
Jack
QAPLA!
Cut/Insert Time - workflow question zakco Pro Tools 10 10 07-11-2012 12:30 PM
Insert Time playlists question summit01 Pro Tools TDM Systems (Mac) 1 10-03-2009 07:41 PM
insert plug in question billybroadsword Pro Tools TDM Systems (Mac) 5 05-15-2009 08:38 PM
Time & Pitch plug-in question dillyllama Tips & Tricks 3 09-09-2006 07:35 AM
How to insert time / insert measures, without upsetting tempo map and markers imp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-25-2003 05:45 PM
