Old 02-14-2020, 06:48 AM
OAG OAG is offline
Default S1 Layout not returning to auto-assigning correctly
Hi.
On 20.1, and I am still finding that switching back on the S1 from a layout with a pre-selection of channels to a layout with auto-assign results in what seems like a random start point.
So, for example, I may have channel 1 selected on Pro Tools (and on the Dock), but when I go to my Bus Master Layout (which I have set up) back to a layout in which all channels are auto-assigned, the S1 is displaying channels 18-25, not 1-8
I have to re-select from the dock or PT (via another channel actually because I cannot just hit channel 1, so it's two selects to get back to where it should be really).
Anyone else having this?
Both tablets updated to latest Control and S1 on new firmware.
Old 02-19-2020, 07:38 PM
EddieJones's Avatar
Default Re: S1 Layout not returning to auto-assigning correctly
What surfaces do you have and in what order in the My list in EuControl. Does changing the order help ?
Old 02-28-2020, 07:04 AM
OAG OAG is offline
Hi Eddie.
I have Avid S1 with Kindle Fire as first device.
Then Avid Dock
Then Huawei T5.
I'll try experimenting with the order if you think it might help.
Is there a recommended order?
Old 02-28-2020, 08:48 AM
EddieJones's Avatar
Thanks...any chance of a video showing this happening ?
Old 03-11-2020, 05:56 AM
OAG OAG is offline
PM'd you Eddie. Hope that's OK.
Old 03-11-2020, 06:31 AM
Lynn Gräber Lynn Gräber is offline
This happens to me too. I have a few different layouts as well as a default (auto assign) programmed to my vertical touch strip. Rarely do the layouts recall correctly the first time. If I touch the softkey a second or third time it usually is correct. I dont know if this is Eucon or the touch strip itself.
Creating Layout with auto assigned track broken in Eucon 19.5 crustn Artist Series 16 07-06-2019 03:08 PM
spilled layout changes display layout kava Avid S4/S6 5 09-05-2018 12:42 AM
Auto Spot not working correctly Felix macOS 2 03-02-2018 03:05 PM
returning to zero DJ Insomaniac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-02-2004 02:40 PM
Auto-assigning outputs??? crsjn Pro Tools TDM Systems (Mac) 4 05-17-2001 07:21 AM
