Latest driver for Mbox 2
Hello everyone! I need to post this again as I was re-installing my OS and ran into a driver issue. I'm running Windows 7 64 bit. I just recently purchased the Mbox 2 and was very excited about it. To explain how it all began prior to the re-installation of the OS, I was able to update the drivers. There were 2 drivers that was found:
1. Digidesign Mbox 2 Audio 2. Digidesign Mbox 2 Midi The Mbox 2 is connecting to the USB port and the light was successfully turn on. I decided to re-installed my OS (I wanted a new clean of my computer again) and now when I try to update the Mbox 2 again, this time it didn't find any drivers at all. All it says is: "Windows could not find software driver for your software. If you know your manufacturer of your device, you can visit its website and check the support section for driver software." Prior to the re-installation of the OS, I was able to use the Mbox 2 with Cubase 4 along with my controller - everything seem to be OK. The main problem now is windows cannot find drivers after I re-install windows. Can somebody help me to download the latest drivers or a recent driver that would work with the Mbox 2 on a windows 7 64 bit OS I would really appreciate the help. Just lead me to the site so I can get the driver up and running, thanks. Here is a spec of my computer overview: SiSoftware Sandra Processor Model : Intel(R) Xeon(R) CPU W3520 @ 2.67GHz Speed : 2.8GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Asus Rampage II GENE BIOS : AMI 0904 07/28/2009 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 6GB DIMM DDR3 Chipset Model : ASUS X58 I/O Hub Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Chipset Model : Intel Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Total Memory : 6GB DIMM DDR3 Channels : 3 Memory Bus Speed : 2x 536MHz (1GHz) Memory Module(s) Memory Module : Wintec 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Wintec 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Wintec 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : ATI Radeon HD 4550 (Microsoft Corporation WDDM 1.1) (SM4.1, 512MB DDR3, PCIe 2.00 x16) Graphics Processor Storage Devices WDC WD7501AALS-00E3A0 (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 699GB (C:) WDC WD7501AALS-00E3A0 (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 699GB (D:) PLEXTOR DVDR PX-880SA (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 2GB (E:) Logical Storage Devices Hard Disk (C:) : 699GB (NTFS) @ WDC WD7501AALS-00E3A0 (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) New Volume (D:) : 699GB (NTFS) @ WDC WD7501AALS-00E3A0 (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) My Disc (E:) : 2GB (UDF) @ PLEXTOR DVDR PX-880SA (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS LPC Interface Controller LPC Legacy Controller 1 : T0 A5-13 Audio Device : ASUS HD Audio Controller Audio Codec : Analog Devices 989Bh Audio Device : Giga-Byte RV730XT Audio device [Radeon HD 4670] Audio Codec : ATI (AMD) HDMI Audio Disk Controller : ASUS 4 port SATA IDE Controller Disk Controller : ASUS 2 port SATA IDE Controller USB Controller 1 : ASUS USB UHCI Controller #4 USB Controller 2 : ASUS USB UHCI Controller #5 USB Controller 3 : ASUS USB UHCI Controller #6 USB Controller 4 : ASUS USB EHCI Controller #2 USB Controller 5 : ASUS USB UHCI Controller #1 USB Controller 6 : ASUS USB UHCI Controller #2 USB Controller 7 : ASUS USB UHCI Controller #3 USB Controller 8 : ASUS USB EHCI Controller #1 FireWire/1394 Controller 1 : ASUS VT6315 Series Firewire Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek RTL8168C(P)/8111C(P) Family PCI-E Gigabit Ethernet NIC (NDIS 6.20) (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Performance Enhancing Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Re: Latest driver for Mbox 2
I forgot to mention something. First I upgraded to PT 8.4 and wasn't able to get any sound out of it, then I switch to Cubase and sound works fine. Then, I reinstalled OS and now couldn't update Mbox 2drivers. So I'm thinking I might have to install PT 8.4 again and see if that will let me update back the drivers.
Also btw, I check inside device manage in the sound and audio section and I see Mbox 2 listed there. That means the driver is there right?
Got it to work in Cubase now.
I finally got PT LE 8.4 open after upgrading from 8.0 wheew! Took a whole day to figured this thing lol. Anyway, I'm still having problem getting sound. Hopefully somebody be kind enough to help me out. PT doesn't use asio4all driver as far I as know. After configuring peripherals set to midi controller (M-audio keyboard) where do I set "received from" and "sent to." Based on the available options I have:
Predefined -> "Digidesign Mbox2 Midi In", "MIDIIN2 (USB Axiom61)" and "USB Axiom 61." Here is the link to the screen pic: http://img41.imageshack.us/i/pt84le.jpg/ As you can see there I have set to "Digidesign Mbox2 Midi In" and "Digidesign Mbox2 Midi out." My Axiom61 is connecting midi in and out into my Mbox2, so I assume that should be the right way to set it? If not, which one out of the 3 choices do I set to? Also here is the main DAW screen shot: http://img59.imageshack.us/i/pt84le2.jpg/ As you can see in the first track, Midi input selector goes to "digidesign Mbox 2 Midi In", and output selector goes to "digidesign Mbox 2 Midi Out." Am I doing it right so far? In the screen shot picture, If you look all the way to the right on the first mixer track, where do I set I/O audio input path selector to, and audio output path selector to? I did armed record the track and play something but I have no sound at all. It's being going on like this for 3 days. Has anybody went through this problem? How do you manage to solve this problem? Here is an update of my computer spec overview. I'm running windows 7 64bit with Mbox 2: SiSoftware Sandra Processor Model : Intel(R) Xeon(R) CPU W3520 @ 2.67GHz Speed : 2.8GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Asus Rampage II GENE BIOS : AMI 0904 07/28/2009 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 6GB DIMM DDR3 Chipset Model : ASUS X58 I/O Hub Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Chipset Model : Intel Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Total Memory : 6GB DIMM DDR3 Channels : 3 Memory Bus Speed : 2x 536MHz (1GHz) Memory Module(s) Memory Module : Wintec 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Wintec 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Memory Module : Wintec 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-9-9-25 4-34-10-5) Video System Video Adapter : ATI Radeon HD 4550 (SM4.1 650MHz, 512MB DDR3 2x750MHz, PCIe 2.00 x16) Graphics Processor STREAM Processor : ATI Radeon HD 4550 (40SP 2C 650MHz, 512MB DDR3 2x750MHz) Storage Devices WDC WD7501AALS-00E3A0 (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 699GB (C:) WDC WD7501AALS-00E3A0 (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 699GB (D:) PLEXTOR DVDR PX-880SA (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) Logical Storage Devices Hard Disk (C:) : 699GB (NTFS) @ WDC WD7501AALS-00E3A0 (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) New Volume (D:) : 699GB (NTFS) @ WDC WD7501AALS-00E3A0 (750.2GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) Optical Drive (E:) : N/A @ PLEXTOR DVDR PX-880SA (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : ASUS LPC Interface Controller LPC Legacy Controller 1 : T0 A5-13 Audio Device : ASUS HD Audio Controller Audio Codec : Analog Devices 989Bh Audio Device : Giga-Byte RV730XT Audio device [Radeon HD 4670] Audio Codec : ATI (AMD) HDMI Audio Disk Controller : ASUS 4 port SATA IDE Controller Disk Controller : ASUS 2 port SATA IDE Controller USB Controller 1 : ASUS USB UHCI Controller #4 USB Controller 2 : ASUS USB UHCI Controller #5 USB Controller 3 : ASUS USB UHCI Controller #6 USB Controller 4 : ASUS USB EHCI Controller #2 USB Controller 5 : ASUS USB UHCI Controller #1 USB Controller 6 : ASUS USB UHCI Controller #2 USB Controller 7 : ASUS USB UHCI Controller #3 USB Controller 8 : ASUS USB EHCI Controller #1 FireWire/1394 Controller 1 : ASUS VT6315 Series Firewire Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 4.8 Performance Enhancing Tips Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Here is also information on sound cards and audio:
SiSoftware Sandra General Information Device Name : Line 1/2 (Digidesign Mbox 2 Aud Manufacturer : 239 Version : 0.00 Product ID : 65535 / 239 Specific Wave Information Maximum Standard Sampling Bits : 16-bit Maximum Standard Sampling Rate : 96kHz Channels : 2 Performance Enhancing Tips Warning 710 : Driver may be obsolete. Check that it is the latest version. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. Is the driver working? Why does it say obsolete? |
MBox "launch control panel" button not working again with the latest driver | Zarabozo | Windows | 0 | 10-26-2012 12:01 AM |
What is the latest driver for Mbox 2 for PT 10/OS X 10.7? | Al West | macOS | 0 | 03-08-2012 06:16 PM |
Latest hardware, latest Windows and Mbox 2 Pro | JustStartingMbox2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-24-2006 06:27 PM |
PT MP7 with projectmix i/o: Latest driver is buggy | thijsvanmenen | Pro Tools M-Powered (Win) | 0 | 01-14-2006 01:25 AM |
Latest ASIO driver? | Whispa | Pro Tools TDM Systems (Win) | 8 | 08-28-2003 11:16 AM |
