Go Back   Avid Pro Audio Community > Legacy Products > Aspera DigiDelivery
Old 01-24-2006, 01:51 AM
Ben D Ben D is offline
Default Digidelivery automation
Hello,
What are the automation capabilities of Digidelivery ?
Can any other client "post" files?
Is there a reference to the command line options of the DD client?
Thanks a lot
/Ben
Old 01-02-2007, 09:03 AM
jmonroe jmonroe is offline
Default Re: Digidelivery automation
Wow, no replies at all? I too am searching in vain for documentation on command line parms to automate sends. Has anyone had any luck?
thanks,
jm
Old 01-18-2007, 06:49 PM
Rick Sanchez Rick Sanchez is offline
I'd be interested to see if anyone has come up with a script to automate downloads. With the LT, it would be very helpful.
Rick Sanchez
http://www.posthastemedia.com
MacPro 2x2.66 GHz Dual Core "WoodCrest"
Mac OSX 10.5.8 / 4 Gig Ram
ProTools 8.0.4
Digidesign/Magma PE6NE-I upgraded 6 slot expansion chassis. (Host card in Slot 2 of MacPro)
HD3 Accel
BlackMagic Decklink Studio 2 (In Slot 3 of MacPro)
SurCode / Dolby Media Meter 2
Izotope RX2 Advanced / Sonic NoNoise
Waves Platinum 7.x / Serato PitchnTime
Melodyne Studio / Altiverb XL / Speakerphone
KOMPLETE 7
EQuality / Massey L2007
TC MasterX
Old 10-17-2007, 03:12 PM
Perhaps with the acquisition, the new developers will address this issue? please?
Old 10-20-2007, 06:01 PM
saran saran is offline
Default Re: Digidelivery server gt not boot disk eror
please help me repair disk utility or restore cd
Old 11-12-2007, 07:09 PM
cmarkle_aspera cmarkle_aspera is offline
Ben,
What are the automation capabilities of Digidelivery ? Can any other client "post" files? Is there a reference to the command line options of the DD client?
Chris Markle here from Aspera... There is currently no generally documented API to the product. I will note that if you invoke DD with a file name on the command line you will at least be delivered into DD with that file name already processed. E.g., (assume in C:\Program Files\DigiDelivery if Windows or equivalent with Mac) digidelivery.exe C:\Documents and Settings\user\Desktop\foo.txt will grab foo.txt from "user"s desktop and fire you up in the client. You have to manually operate from their. Windows SendTo will work similarly of you add DigiDelivery to the set of SendTo target programs.
Chris
Old 04-05-2009, 02:58 PM
Originally Posted by cmarkle_aspera View Post
Ben,
Chris
Chris, will the new 3.0 software accept the rest of the parms from the command line without requiring a GUI popup? (I hope.)
thanks.
someone please help with digidelivery jonnymacinc General Discussion 1 04-13-2010 01:29 PM
DigiDelivery ? mushmouth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-13-2006 11:50 AM
DigiDelivery Pirate Post Post - Surround - Video 11 02-19-2004 11:53 AM
DigiDelivery james123 Pro Tools TDM Systems (Mac) 17 01-14-2004 12:34 AM
digidelivery gumbiman General Discussion 4 12-31-2003 05:06 PM
