Old 08-09-2020, 09:29 AM
cdragon1 cdragon1 is offline
Default Strong input signal but no sound monitoring or playback
I just got Pro Tools and I can't get any sound to come through from my interface or my MIDI controller even though I can see my levels going up on the mix window. I've checked my hardware, playback engine, I/O, pro tools preferences, my system preferences, and I have low latency monitoring off. I've looked all over the internet for a fix but nothing has helped. I hope this is good enough of a description cuz I suck at explaining things.
I'm using a Dell Inspiron 7791 2n1, i7 processor, 16GB RAM with Windows 10
Steinberg UR22 mkII
Akai MPK mini MIDI controller
Old 08-09-2020, 09:47 AM
Default Re: Strong input signal but no sound monitoring or playback
Hi, welcome to the community.
First import some audio to your PT session and try to playback. Until you can get something pre-recorded to playback you have no idea what is going on.
Old 08-09-2020, 10:29 AM
^^^ and once you have that working. Then you need to explain what you are trying to record. You mention MIDI and interface... What exactly are you doing? Get audio recordings to work first.
Common mistakes are to try to record audio to an instrument track when you need to use an audio track, or MIDI to a MIDI track When you should use an instrument track with a VI plugin inserted on it.
If you are totally new try to find a beginner tutorials to follow to do stuff similar to what you are interested in with similar versions of Pro Tools and follow those step by step.
Old 08-09-2020, 10:30 AM
Still getting no sound from the imported audio.
Old 08-09-2020, 10:34 AM
I'm recording MIDI on an instrument track with Xpand2 and audio on the audio track. I've watched a few tutorials and am able to get everything set up properly (to my knowledge anyway), just no sound.
Old 08-11-2020, 12:12 PM
Bob L's Avatar
Bob L Bob L is offline
Have you gone to I/O Setup and defaulted the Input and Output tabs?
Bob
Without a song
The day would never end
Old 08-11-2020, 01:00 PM
That^^^, and also open Setup>Hardware and make sure that the Steinberg is the selected "Audio engine". Are you working with speakers or headphones? Check all connections(even me, with 35 years under my belt, has been known to mis-patch something). And, since you are on Windows, open Settings>Sound and make sure that the Steinberg interface is NOT being used as the Windows default playback device
Youtube is a decent source of free tutorials to get started. Groove3 is a paid deal but everyone I know that has signed up has been very happy with the results
Old 08-12-2020, 03:27 AM
Well I just found the problem. I wasn't getting sound from my headphones plugged into the laptop but I used the 1/4 inch cable I got from the headphones and plugged them into the interface and I have sound now. I feel stupid but I'm glad I figured it out haha
I went to the setup app in the hardware tab and got this error. Maybe this has something to do with why I'm not getting sound from the laptop. I'm just gonna plug the headphones into the interface from now on but does anyone have an idea of what this could be? "Audio interruption due to USB error is detected. Refer to the troubleshooting in the operation manual."
Old 08-12-2020, 07:58 AM
K Roche's Avatar
K Roche K Roche is offline
PT can only output through the chosen audio device So if you are using your interface as your audio device, it won't output through the computer sound card .
I don't use it but MacOS has an aggregate I/O where you might be able to this but I do not know about Windows
System :
Enjoy the Journey
.... Kev...
Old 08-12-2020, 09:23 AM
You can do some aggregation on Windows via ASIO4ALL... and that's a much much worse idea than aggregating CoreAudio devices on macOS. And that's already pretty bad idea. Pro Tools is what it is and wants to work with a single audio interface
No Signal Level and no input monitoring beccatan92 Pro Tools 12 7 09-12-2016 11:15 PM
Pro Tools LE 8 -- No sound, but strong input signal carterisgod41 FireWire & USB Audio Interfaces (Mac) 15 03-18-2014 08:42 PM
Input signal still live during playback? Red-Dave Pro Tools 10 0 10-09-2012 01:25 PM
monitoring Mic signal during playback. figment 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 07-08-2007 07:58 PM
monitoring Mic signal during playback. figment 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-07-2007 08:49 AM
