Old 05-08-2018, 05:52 AM
kris.audioplanet's Avatar
kris.audioplanet kris.audioplanet is offline
Default Recording live in a mix
Hi
Is there a way to properly deal with latency while recording a track live to an already existing mix that uses a lot of busses and high latency plugins? I am trying to record a Hammond and a Rhodes and they both end up lagging. I use Apollo for low latency monitoring instead of pro tools.
MP 6,1, 4 Core, 64Gb RAM | I/O - UAD Apollo and Twin MKII | Pro Tools Native 2018.3
Old 05-08-2018, 06:42 AM
peterle peterle is offline
Default Re: Recording live in a mix
...savest way is to freeze/commit those latency hungry
tracks (mostly VI but also few PlugIns) before recording new ones,
takes only few minutes and saves a lot of headache
foley artist , soundeditor
Old 05-08-2018, 10:55 AM
Extreme Mixing Extreme Mixing is offline
Yes. Or just bounce a rough to play with.
Steve
Steve Shepherd
Extreme Mixing
Old 05-08-2018, 11:52 AM
off the wall's Avatar
off the wall off the wall is offline
Steve
^^THAT^^
This happens ALL THE TIME with my clients. Just do a quick stereo bounce and track to that. Import back into mix session.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 05-08-2018, 11:57 AM
CygnusX-1Bk2 CygnusX-1Bk2 is offline
Or you can disable the plugins and change the output routing on the track you are trying to record to.
I will choose,
Freewill
http://jimdiazaudio.com/
Old 05-08-2018, 06:53 PM
Whenever possible, I try to keep all high-latency plugins in the same slot(like all in Insert row F) so I can make the entire row inactive with a single command(which makes it fairly fast and easy). Another thing I do(just my preference) is avoid tons of bussing. Now I get the logic(bad pun), but just because you CAN do this, doesn't mean you should(or MUST). Just one opinion
Old 05-09-2018, 09:10 AM
climber climber is offline
Steve
I do this whenever I need to do this. works great & they play along & record with the fully mixed track.
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 05-09-2018, 09:11 AM
this is a pain to do and you run the risk of forgetting something when you switch things back.
Al Hospers
Recording Guitar w/Effects live recording The-Edge Getting Started 1 09-21-2016 05:33 PM
Live Recording Roger Stauss VENUE Live Sound Systems 2 08-17-2007 12:46 PM
Ableton Live - performing/recording live w/HD3 Surth Pro Tools TDM Systems (Mac) 1 09-11-2006 04:50 AM
Can I do this live recording with PT ? deardaddy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 52 10-26-2004 11:33 AM
Battery Life when live recording W/Mbox live Paver 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-16-2003 12:14 PM
