Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 04-30-2018, 06:31 PM
BurbankGuy BurbankGuy is offline
Default Command 8 connectivity + Pro Tools 10+11 HD
Hi folks,
I was running PT 10 HD1 on Windows 7 64bit Gigabyte X79-UD3
I regularly would get the error that
"Pro Tools cannot communicate with Command 8".
I'm now running PT 11.3.2 on one HDX card.
I just got the same Command 8 issue.
All the drivers are loaded. I know that C|8 is not officially supported in 11 but it was in 10 and I'm having the same error in 11.
Does anyone have an idea as to what's causing this? The C|8 is in the Device Manager with no problems.
Thanks in advance!!
Old 04-30-2018, 07:21 PM
Default Re: Command 8 connectivity + Pro Tools 10+11 HD
Did you turn off the power management feature on all USB ports?
Old 05-01-2018, 09:22 AM
Hi Dave!
I did make sure all the power management was off.
Just today at startup the C|8 simply won't talk to PT.
I unplugged, ran a different cable and used a different port and set it in Midi as #3.
We'll see what happens.
Maybe the C|8 has physical issues with the USB port?
So confusing.
Old 05-04-2018, 09:59 AM
Has it ever worked or are trying to get started with the Command 8? If this is a new addition to your setup, maybe check some youtube videos and see if there is a setup thing you are missing
https://www.youtube.com/results?sear...ontrol+surface
Old 05-07-2018, 11:50 PM
Dave
I've been using the C8 for years now. I was speaking with some Avid repair people here in town just to see if there might be a hardware issue with the USB section.
It might just be something that's interrupting the C8 connection. So, I'm swapping out some things like my mouse, etc to see if a different port might help.
It stopped working in the middle of a session today. Thankfully the old #3 on the numeric keypad worked so I could continue tracking.
I have to shut down PT, power cycle the C8 and reboot for it to come back.
I'm about to just scrap it for a PreSonus FaderPort 8.
Thanks for answering!
Old 05-08-2018, 02:44 AM
Raoul23 Raoul23 is offline
Just sharing my experience with the command 8. When I was on Windows some of the faders would not work correctly or track the fader position on the screen. As I brought the command 8 second hand I thought it was just faulty. I then sold it when I got my raven and then when I sold my raven I brought another command 8. This 2nd command 8 had the same problem as the first one I had. I then switched to Mac and the Command 8 works fine. Strange huh
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 05-08-2018, 11:39 AM
Ha!
Not strange at all.
Windows is the red-headed step child in the Pro Tools world.
Plus, they've never really upgraded any of the software for it.
You'll probably see this on Craigslist soon!
Old 05-09-2018, 04:48 AM
YYR123's Avatar
YYR123 YYR123 is offline
Originally Posted by BurbankGuy View Post
Dave
Yeah I think I was all mac when I was using mine. So that might explain why I never had any issues running my C|8.....super functional little controller.
I am not sure going HUI is going to make you feel better.....it might feel like a step backwards>> demo before you buy, or buy sweetwater so you can return.
Daniel
Old 05-11-2018, 07:23 PM
I probably don't use the full functionality of the C8. I mainly use the transport, faders and pans.
I'm trying to avoid using a mouse/trackball too much.
Pro tools noob question - connectivity brawley17 Getting Started 2 03-27-2014 06:14 PM
Pro Tools Input Connectivity with ART Voice Channel kaikaneronning Windows 4 01-03-2013 06:40 PM
When will we see AVB connectivity for Pro Tools? digidesigner Pro Tools 10 2 01-24-2012 09:07 AM
Pro Tools HD, DigiLink and Third-Party Connectivity Avid General 0 02-13-2002 12:56 AM
Pro Tools and MFX Connectivity Software BobbyDazzler General Discussion 0 06-06-2000 05:01 AM
