Old 04-26-2019, 05:09 PM
jgiannis jgiannis is offline
Default Re: HD OMNI optical inputs
Originally Posted by Top Jimmy View Post
In your picture, you have the same input selected for channels 5-6 and 7-8. If there’s a 2nd S/PDIF available, it has to be selected in one of the input pairs.
I thought of that too. But there is not a second option. There is only 1 optical in the drop down.
Old 04-26-2019, 05:11 PM
Top Jimmy's Avatar
Then by process by elimination, you can only use the 1 port for S/PDIF and the documentation is faulty.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 04-26-2019, 05:12 PM
BScout BScout is offline
What James said.
You are just duplicating the same input.
There is nothing wrong with your Omni.
For S/PDIF optical you get 2 channels and 2 channels only (L/R) on port 1 for input.
The second port is for higher sample rates when S/MUX2 and S/MUX4 is needed.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 04-26-2019, 05:18 PM
You don't get 4 channels of S/PDIF in any form (coax or optical.) Only 2.
HD Omni Optical GaryCar Pro Tools HDX & HD Native Systems (Mac) 1 09-10-2015 07:52 AM
MacBook Pro Optical out into Omni optical In? KenSluiter Pro Tools HDX & HD Native Systems (Mac) 2 01-14-2015 04:37 PM
omni - how to use both optical inputs simultaneously? lemieux Pro Tools HDX & HD Native Systems (Mac) 4 10-07-2014 08:39 PM
Trim Optical Inputs on OMNI? dwaynedelario Pro Tools HDX & HD Native Systems (Mac) 13 03-13-2013 01:34 PM
192 : MUST select Optical format for Bay 3 to activate Enclosure Optical inputs????? el biciclista Pro Tools TDM Systems (Mac) 2 07-09-2002 10:32 AM
