PT11 with Slate Raven
I'm trying to use the Slate Raven as my controller for PT11, but can't get it to work correctly. It works fine in PT10, but V-Control won't connect in PT11 to allow me to use the external mixer and transport functions from the Raven. I went through 3 hours of troubleshooting with Slate this morning, and couldn't solve the problem. They are GUESSING that maybe because I'm using a Digi 002r as my interface, the drivers aren't compatible.
Anyone else using a Raven with PT11 on Windows with a Digi 002r? (Obscure enough for ya?) :P TIA
================================== Ryzen 7 5800X, ASUS TUF Gaming x570-PLUS (WIFI) motherboard, 32gB 3200mhz memory, Windows 10 Pro, Focusrite 18i20, Raven Mti2, Protools Studio 2022.5 |
Re: PT11 with Slate Raven
What windows are you using it on. I had major issues with windows 7 and my raven
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Windows 10 Pro.
Like I said, the Raven works perfectly in PT10, and everything BUT the V-Control stuff works in 11. Just can't get the transport and mixer connected.
http://avid.force.com/pkb/articles/e...ility/en353257 These were mainly Batch Command issues if I remember correctly, gcasper is having troubles with V-Control Pro and PT11 with the 002r. |
UPDATE: I spent several hours last night working on this with a tech from Neyrinck Audio, the guys who write the V-Control software, which interfaces the Raven to the PC. We discovered that there is something wrong with the way the interface handles the Digi 002r in PT11 on Windows 10, BUT there is a workaround we discovered. I powered down my 002r, started V-Control Pro, loaded up PT11, opened a session using ASIO4ALL as the playback engine, then loaded the Raven software. Everything worked. Then I powered up my 002r, changed the playback engine to the 002r, and voila! It worked! So it has something to do with having the 002r powered up when you load the software. If you power up AFTER the software is already loaded, everything works.
A big thanks to Jamey at Slate and Joshua at Neyrink Audio who both helped figure this out!
S6 and Slate Raven? | Marsdy | Avid S4/S6 | 20 | 08-30-2017 07:24 PM |
Slate RAVEN is now available for Windows + P.T | Seafoam_Green | Windows | 10 | 09-14-2016 08:50 PM |
Avid S3 or Slate Raven MTX | Oblivion777 | General Discussion | 20 | 12-07-2015 10:41 AM |
Slate Raven MTX & MTi | bakedbeansrecord | Pro Tools HDX & HD Native Systems (Mac) | 9 | 12-10-2013 11:52 AM |
New slate raven x1 console. | Emcha_audio | General Discussion | 12 | 10-29-2012 07:41 AM |
