Old 05-31-2014, 06:18 PM
pbmeese pbmeese is offline
Default Requesting New Authorization Code for replacement Ilok
Hello,
I recently lost my Ilok that activates my PT 10 LE. I purchased a new one from Guitar Center and downloaded the temporary code to activate PT. The temp code that came with my new Ilok is now expired. I went to Avid.com to request a new PT activation code and could not find (or somehow overlooked) any way to submit a request. I have active Avid and Ilok accounts. Is there a quick way to request and receive a new activation code for my new Ilok?
I also hope to remain on PT 10 and not be forced to upgrade to 11.
This is my first thread although I've been a PT user for 10 years now. Does any one have a solution to this problem? Thanks.
Old 05-31-2014, 07:18 PM
Bruce Paine Bruce Paine is offline
Admin Emeritus
Default Re: Requesting New Authorization Code for replacement Ilok
In order to get a permanent replacement license, you need to start by reporting the iLok as lost or stolen at iLok.com
From the Support FAQ in the forum header:
What should I do if my iLok is lost or stolen?
Bruce Paine
System Details
Old 06-01-2014, 07:03 AM
nigelpry's Avatar
nigelpry nigelpry is offline
And you won't be able to upgrade to PT11 without getting your replacement PT10 licence, because the upgrade process requires your old licence to be surrendered before your new licence gets deposited onto your iLok.
You might want to consider iLok's ZDT (Zero Downtime) service for the future. For a fairly smallannual fee, iLok will supply you with a new permanent licence, free of charge, if your iLok is lost/stolen in the future.
It works by requiring you to connect to iLok.com at least once every 90 days with your iLok attached to the computer to validate it. If you don't connect in that timescale, the licences stop working until you do connect.
New permanent licences can be issued if you have ZDT cover because, if someone gets your lost/stolen iLok, it will stop working after a maximum of 90 days, assuming they don't know your iLok.com login details. So the companies you bought software from will let iLok issue new replacement licences to you.
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10
iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6
Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors.
Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3.
Various apps, soft synths, FX plugins.
Plenty of hardware synths, rack gear, microphones etc.
And then there's the studio ;-)
error: missing ilok authorization for pro tools... please insert the necessary ilok. Witold.B Pro Tools Express on Mac OS X 1 04-21-2014 03:59 AM
Authorization code vs ilok on legacy 7.3.1 pontaluna macOS 3 01-08-2014 01:39 PM
Will AVID supply replacement disc or download code? [email protected] macOS 4 09-08-2012 01:15 AM
i need help with my pro tools 7le authorization code code NDepthProductions Pro Tools M-Powered (Win) 6 03-14-2008 01:30 PM
PT LE 6.4 prompted for authorization code using ilok distratman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-20-2007 03:47 PM
