Old 03-24-2011, 07:08 AM
fastnboulbous fastnboulbous is offline
Default Eleven Rack compatibility problems?
I am having problems when I connect my Eleven rack to my iMac.
I am using protools 9 with an RME Babyface as my main interface.
When I start up with the Eleven Rack either switched on or turn it on after the computer has started I get no sound. Only intermittent crackle. If I unplug the ER from my computer and reset the memory it works fine. Until I try to connect it to the computer again.
I have tried the Eleven rack plugged into another iMac and it worked fine and have also tried different USB ports on my Mac to no avail.
All the latest drivers and the latest firmware are installed for the Eleven Rack.
One thing though, even though I get no sound, when I launch protools the computer will still see the Eleven Rack, it will load but the on screen interface will not show. The Babyface also uses an onscreen interface called Total Mix.
I am thinking there may be some software conflict/compatibility issue.
Anyone got any suggestions?
Thanks in advance
Eleven rack Live problems. Angelo Bruschini Eleven Rack 0 09-18-2013 08:49 AM
Eleven rack problems with Imac battledog Eleven Rack 4 07-21-2012 01:46 PM
Eleven Rack Problems hero12300 Eleven Rack 8 06-26-2012 10:14 AM
Eleven Rack Problems with USB e Drivers DaniTo Eleven Rack 1 06-23-2012 06:05 PM
Problems using eleven rack with cab rootyjooser Eleven Rack 3 06-19-2011 01:20 PM
