#31
Re: eMix 6.0.3 Hybrid will not connect to EuconWS 3.3.2
Did you do a clean uninstall of 3.3.2 or whatever that earlier version was. Don't even try with anything other than 3.6.1 WS installer as it wont work (different EUCON) even if it does show up.
Clean EUCON Script On the SC264, when you say clean install was that after uninstalling eMix and then the Hybrid App. If you back up titles etc. you could then delete the eMix directory. (but you shouldn't need to, all others using this software are connecting OK) |
#32
I've done clean install on clean win image both on sc264 and ws side for several times. Are there an EuCon uninstaller available for win pc?
*Notice: I am running a xeon win10 ws with PT11 and Cubase7+ 8.5. None of the DAWs connecting or ws showing up in lower garage. Have also tried another ws. It still seems for me like the two last shipping EuCon WS installers for windows are developed for MC, and does not work with Hybrid...? Thanks!
Avid System 5 Fusion Console (Hybrid) SC264d - SP663 - eMix v6.1.0 Intel Xeon 12core 64GB RAM Win10 Avid HD Madi SSL Soundscape 128Madi ProTools 11 - Cubase 8.5 Avid ML530 - AM713 - MA703 - SSL AlphaLink - MC524 Genelec 1038 + D&B Q1 - QSub - D12 mains TC M6000 MKII - Lexicon 480L |
#33
Can you try this, Open the HybridApp.ini file that is in Hybrid installation folder on the SC264 and add ; in front of the network lines as per this image. Then save it. HybridApp.ini pic. Restart everything and try to connect (making sure you are using the 3.6.1 EUCON) If that doesn't work you need to change the network port order metrics. To do this find the network adapters in the SC264 Windows Control Panel and right click on the EUCON/Hybrid Ethernet adapter (not S5) and select properties. See image for what to do and change.. Network Metric change image |
#34
Windows Pro 10 X64 - Pro Tools 12.8HDX Windows Pro 10 X64 - Nuendo 10 Windows Pro 10 X64 - Cubase Pro 10 Euphonix System 5, 408's, 401, 402, 403 eMix 6.1.1.20.1, HybridAPP 20.1, EuconWS 3.6.1 |
#35
I would first try the two things I described above then if those don't solve the issue you can try the static address route. If the SC264 and your Workstations are the only things on the EUCON network (recommended) then you can set all of them to a static address. You do this in the IVP4 settings in Windows (see previous image) or the network preferences on Mac. Use something like IP 192.168.100.1 Subnet 255.255.255.0 for the SC264 EUCON port and then IP 192.168.100.2 Subnet 255.255.255.0 for the WS. If you have more Workstation's then carry on the numbering 3, 4, 5 etc. Edit: Don't use any addresses in the range 192.168.0.x to 192.168.25.x S5 uses some of these. |
#36
Well, I'm very happy to announce my system is now at last 100% functional!
I'm ashamed to tell I had Cubase 6 installed on both WS's tested. It was the previous necessary Steinberg Eucon adapter which took control on EuCon and made it go bananas wether running PT or Cubase Uninstalled Cubase 6 + Steinberg adapter. EuCon is up running stable and better than ever both with PT11 and Cubase8.5. Thank you so much for all your help and patience! Fantastic!
Upgrading from Hybrid 1 to Hybrid 3? | tuomiopäivä | Virtual Instruments | 2 | 01-11-2016 12:01 AM |
Emix v6 VCA spill | bergj00 | System 5 | 0 | 10-06-2014 08:23 PM |
Emix v5.3 software with Pro Tools 11 support now available | H.G. Hollans | System 5 | 0 | 02-04-2014 08:55 AM |
Emix version and changelog | putney | System 5 | 4 | 01-07-2013 08:20 PM |
PT 8.0.3 no Hybrid | 6figgas | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 05-01-2010 05:28 PM |
