Old 07-01-2020, 08:54 PM
jonpaulr123 jonpaulr123 is offline
Default Connecting iPad via cable for faster connection?
Hey everyone, I just got the S1 and am noticing that when the iPad is connected via wifi it's a bit laggy with pro tools and the S1. Is there a way to connect it via a cable that will take this lag away?
Thanks!
Old 07-01-2020, 10:05 PM
asm's Avatar
asm asm is offline
I am using a iPad Pro, with usb-c, connected to the following;
https://www.cablestogo.com/product/2...p-to-60w-black
I also use a short usb-c extension cable to hide the adapter under the desk: https://www.cablestogo.com/product/2...n-cable-10gbps
This provides power as well as gigabit ethernet to the iPad (also works with my 13" MacBook pro, since I am using a 45W power supply.)
Meters and controls definitely seem more stable/responsive.
If you have an iPad with the lightning adapter, you can use something like this: https://www.belkin.com/us/p/P-F8J227/
Andrew Mittelman
www.soundgeneration.net
Old 07-02-2020, 04:38 AM
Oggy Oggy is offline
Default Re: Connecting iPad via cable for faster connection?
Is your wifi off? On the ipad?
Old 07-02-2020, 07:24 AM
Great thanks!
Issues Connecting iPad to Eucontrol Windows 10 JakeBirch Avid S1, S3, Dock and Control App 2 03-08-2019 01:54 PM
iPad via lightning cable - not working - how to set up? Sir Hannes Avid S1, S3, Dock and Control App 7 07-14-2017 12:48 PM
Ipad PTcontrol with ethernet connection Ale Avid S1, S3, Dock and Control App 1 02-16-2016 09:08 AM
Longer connection-cable? cambiata 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-27-2000 02:43 PM
