Old 08-19-2019, 03:06 PM
BScout BScout is offline
Default Re: Converting SD2 files to wav on mac
Edit: Duh. I could use the file type search for that too, right?
Edit 2: Still, all the SDII files in the audio files folders would also show up...
Edit 1: Exactly
Edit 2: Until you remove them (if you wish) through the finder search. (from the search window, you can also "open file location" to spawn another finder window to show where those files are located if you need to do something more to those specific SDII file(s))
Pro Tools Ult 2024.3, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface ProS1 x 2, Fire HD10 + Max11, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 13.6.5RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
Old 07-06-2020, 09:17 PM
nikseven nikseven is offline
Digging this thread out of the grave just because I had the inevitable challenge of converting SD2 files of some old mixes today (not a full old pt session, just some old mixes), and just in case it's helpful to others, I used Izotope RX to do the conversion and it was super easy. RX recognizes SD2, and allows for export in other formats. Dragged and dropped the SD2s into the spectral editor then just file>export. Easy.
Old 07-07-2020, 01:17 AM
Stephen Bond's Avatar
Pro Tools 10 is you friend! I tried other methods and failed.
I boot an old hard drive and run it from there. You'll need a compatible system and PT10 in your iLok.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Converting Vision files to ProTools or general midi files!!! Paata 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-17-2008 01:11 PM
Converting wma files mrmxed Pro Tools TDM Systems (Mac) 2 04-17-2007 08:26 AM
Converting Cubase files to Pro Tools files... salty_dawg3 Pro Tools M-Powered (Win) 4 12-07-2006 01:58 PM
converting files from 7 to 5.1 John fatman Pro Tools TDM Systems (Mac) 5 02-13-2006 05:53 PM
Converting midi files to audio files Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-19-2003 03:23 PM
