Old 06-13-2018, 10:14 AM
Top Jimmy's Avatar
Default Digi 002 MIDI problem
Originally Posted by Timi View Post
I don't think it's the controller, as it wasn't working with my friend's newer Korg either.
This was never a problem when I used an mbox. Thanks for your ideas!
I see a lot of information on the Audio MIDI Setup utility when clicking the Info tab... Do you think any of this may be a clue? (see attached screenshot)
You shared a picture of the audio devices in audiomidi setup, now open the midi devices window of audiomidi setup and see what's going on there. Look in either the view or window menu for the midi devices window.
James Cadwallader
Old 06-13-2018, 10:16 AM
Timi Timi is offline
Default Re: Digi 002 MIDI problem
You're correct. Neither controller produced sound, but again, they are lighting up the MIDI IN light on the face of the 002.
I tried trashing the preferences and databases.. No change
I really appreciate your help!
Old 06-13-2018, 10:30 AM
Top Jimmy this is what I am seeing....
File Type: jpg Screen shot 2018-06-13 at 1.30.00 PM.jpg (34.2 KB, 0 views)
Old 06-13-2018, 01:10 PM
Top Jimmy's Avatar
The MIDI Studio window shows that the 002 is not present as a MIDI interface. If it were, it would have the in/out arrows on the bottom not the top. The Digi 002 and Ensoniq entries you have are devices that you've created.
I would suggest resetting the iMac SMC, zapping NVRAM, resetting permissions and all the usual Mac tweaks. If that doesn't work, then a clean uninstall and reinstall of all things Pro Tools and 002 related. If that doesn't work, then a reformat and fresh installation of Mac OS. If that doesn't work I would conclude that something is wrong with the 002.
James Cadwallader
Old 06-13-2018, 01:26 PM
Top Jimmy's Avatar
Another thing you can try first is creating a new MIDI Studio configuration. This will only work if you 002 is present and on. Click the dropdown menu in the MIDI Studio window and choose New Configuration. This should make everything available that is attached to the Mac.
James Cadwallader
  #16
Old 06-15-2018, 08:30 AM
Thanks for the suggestions! I'll be trying this asap but I have to take a hiatus to work on some other things. Really appreciate you.
Timi
Problem with Digi Audio Midi Set Up in 8.03 michael c Pro Tools TDM Systems (Mac) 2 01-06-2010 09:49 AM
digi 002 - midi problem! Sf Audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-29-2008 09:12 PM
MIDI problem with my Triton & my digi 001....HELP! TACT OUT MUZIC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 08-08-2005 07:46 PM
Digi 001 Midi Problem dnkygirl MIDI 4 05-10-2005 10:11 AM
MIDI problem with Digi 001 a u t o h y p n o s i s 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-09-2003 12:46 AM
