What is AAE error -35 ?
I keep getting the AAE error -35. Can anyone tell me what this means?
I am currently on PT HD 11.0.0 on a MacBook Pro I7 (mid 2010) w. 8 GB RAM using the build-in output. I know this set-up is not optimal, but it is a quite light session I am trying to run, so I didn't expect too many problems... I am trying to do some editing (about 10 tracks of audio, only a couple of Avid standard plug-ins + a QT H264 video file) - but I keep getting this error every 15 minutes or so... Also, does anyone know where to find a complete list of the AAE error codes? Thanks. |
Re: What is AAE error -35 ?
Timothy |
I'd start by updating to 11.0.1.
.0 releases have to get out the door on timelines and often the first update fixes lots of little stuff. |
Timothy |
Yes, several weeks ago.
http://duc.avid.com/showthread.php?t=340980 Keep an eye on the technical alerts forum. |
how could I have overlooked that. Thanks Drew. Timothy |
Hope it help the OP!
Glad to help. |
I got this error 35 after I renamed some files in the session. Reverting the last saved version or session backups didn't help and I basically lost the whole session. Error box keeps coming all the time.
Thanks for Time Machine I got my working version back. My error was 35, not -35. So maybe it's not the same as OP had. |
I just found that, if I had a network drive with the same name mounted, pro tools would generate aae 35 error. Once I dismounted that drive, and restarted pro tools, it was smooth sailing. Must be confusion in differentiating between two drives of the same name, even though one is local and the other networked.
Hope this helps. Cheers |
H/W Buffer Error (pro tools error -6104) Only 1 audio track running. | kieran.mia | macOS | 1 | 01-29-2013 01:39 AM |
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error | EricMulhern | macOS | 1 | 11-20-2011 05:39 PM |
Scorch store transaction error. You succesfully paid for this score but an error..... | deepfriedpizzainbatter | Avid Scorch (iOS) Forum | 9 | 11-07-2011 06:08 AM |
Error type 10,address error ,illegal error, buss error ,illegal instruction | KasticK | Pro Tools TDM Systems (Mac) | 3 | 05-14-2003 11:21 AM |
Buss error,Address error,ilegal instruction,error type 10 | KasticK | Pro Tools TDM Systems (Mac) | 1 | 02-08-2003 05:49 PM |
