Old 07-17-2018, 04:11 AM
groovebrother groovebrother is offline
Default Re: Recording with Superior Drummer and V-Drum
Originally Posted by Stig Eliassen View Post
It's under memory & status in the construct page.
there is a button "cached" but if i unselect it + clear samples loaded +reload samples it does nothing more but silence when i hit v drum pads
My soundcloud page
Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8
Old 07-17-2018, 04:15 AM
okay got it !!!!!!
at my last answer my son had unconnected the V DRUM usb cable
THANK YOU SO MUCH !
THANK YOU SO MUCH !
THANK YOU SO MUCH !
THANK YOU SO MUCH !
THANK YOU SO MUCH !
THANK YOU SO MUCH !
My soundcloud page
Old 07-17-2018, 04:19 AM
Stig Eliassen's Avatar
My absolute pleasure. Glad to help
Old 07-17-2018, 04:21 AM
(you are gonna laught ... or not)
i forgot that i had standalone mode active so i thought sound was coming out of pro tools
argh
any onther clue ?
would you have a way to send me screen captures of all your settings ?
My soundcloud page
Old 07-17-2018, 04:28 AM
What is your exact hardware and connection(s), and how have you set SD2 up in PT?
  #16
Old 07-17-2018, 08:31 AM
i have
- mac pro westmere 2x 2,66 with 6 core + 32 go ram
- pe6r4-i filled with accel cards
- 10.6.8 / PTHD 10.3.10
- 2x 192 i/o
- usb uno midi interface for the TD4 roland
- mtpav for all keyboards
- R 400 S sonnettech HDD chassis
- SD2 is inserted on instrumentrack (insert a) routed in the masterfader using the avatard sound bank
- SD2 's mixer is in multitracks mode from kick to last track
- 15 stereo auxiliaires in pro tools
- all stereo AUX are routed from aux 1 to the last "S3/4" ... "S31/32" from SD 2
Mac midi setup :
- Has the mtpav with 2 keyboards connected.
- Usb uno midi interface : nothing connected - but i have tried to create device like TD4 connected to the usb uno interface : it hasn't changed anythnig so right now : nothing's connected to the uno usb)
- Midi beat clock : all is checked including superior drummer multiout 1 + usb uno midi interface
- Midi filters : left as default
- Midi inputs : all is checked
Peripherals menu :
- Sync : MTC generator : default / MTC reader : none
- Machine control : left unchecked
just as a reminder :
With actual settings i can record what i play with SD 2 through the v drums and it's okay when i hit play in pro tools after recording.
i have sound return when i play SD2 in standalone mode - wich i am force to use if i want monitoring while recording in pro tools
i just do not have sound return in pro tools when trying to avoid using SD2 in standalone mode.
My soundcloud page
  #17
Old 07-17-2018, 05:47 PM
i guess clicking "midi thru" (checked) in the options menu made it work
does this make sence to you ?
My soundcloud page
  #18
Old 07-18-2018, 12:05 AM
Absolutely. It's there so you can monitor record-enabled MIDI tracks.
Snare drum sound in superior drummer Raoul23 The Drum Room 10 06-25-2011 10:51 AM
EZ Drummer and Superior Drummer Problems verticleman Virtual Instruments 5 01-02-2011 11:41 AM
Superior Drummer and EZ Drummer on sale nst7 Virtual Instruments 0 09-01-2010 09:57 AM
EZ Drummer Superior vs PT8 dqattan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-03-2010 06:58 AM
Ez-Drummer and Superior Drummer by Toontrack Narzugon Virtual Instruments 3 12-17-2008 08:06 PM
