Old 04-21-2008, 09:10 PM
p.richardson3 p.richardson3 is offline
Default presonus firepod
does anyone know if the presonus firepod 8 channel interface can be used with pro tools m-powered 7.4 and/or can the firepod be used for anything more than just an interface for pro tools le? for example instead of an m-box or an 002/003? thanks in advance for any info.
Old 04-21-2008, 11:25 PM
JMS40 JMS40 is offline
Default Re: presonus firepod
The Firepod can't be used as an audio interface for either product.
Pro Tools M-Powered requires M-Audio hardware.
Pro Tools LE requires Digidesign hardware.
Old 02-14-2009, 10:21 AM
EMGactive EMGactive is offline
Is there anyway to connect the Presonus Firepod to the Digidesign 003?
Old 02-14-2009, 12:21 PM
sw rec sw rec is offline
If the Presonus has lightpipe you can use it to access the "ADAT" i/o on your 003.
Old 02-14-2009, 12:25 PM
No lightpipe on the Firepod...
Old 02-14-2009, 12:27 PM
"No lightpipe on the Firepod..."
There ya go. Maybe look for some killer plugins instead....
Old 02-14-2009, 10:33 PM
What would be a good interface with lightpipe to use with the 003 that is at a decent price?
Old 02-15-2009, 10:38 AM
Behringer ADA 8000
Old 02-15-2009, 10:43 AM
Chase743 Chase743 is offline
The Digimax D8 is a little more expensive, but if you bargain hunt, you can find one for around $400. Sounds far better than most of the other non-Presonus units in the same price range.
PC: Dell Studio XPS 9000
Hardware: 002r, Mbox 2, Digimax D8, ART Pro MPA II (w/ Mullard Tubes)
Guitarist | Singer | Songwriter | Engineer
www.stolenalibi.com
Old 02-15-2009, 02:05 PM
Thanks to everyone, you've all been very helpful.
Presonus Firepod with Pro Tools 9 Prages Windows 0 05-27-2011 02:09 PM
PreSonus FIREPOD and Pro Tools M-Powered jaredbh Pro Tools M-Powered (Win) 0 04-19-2007 05:38 PM
presonus firepod as an 8 ch direct pre? Ken P 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-06-2006 09:43 AM
PreSonus FIREpod With Digi002 and pro tools??????? DrummerGuy09 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-05-2005 09:47 PM
