Old 03-02-2004, 12:02 AM
drguitar drguitar is offline
Default digi 002 high pass filter switch
has anybody ever had to use these switches on the first four inputs of the digi 002? and if so, can you give me of an example of when you needed it? might be a dumb question....I'll guess whether or not I get a reponse from anyone will determine that
iMac 27 inch Quad Core 3.4 GHz
OS X 10.8.2
24 GB RAM
Digi 002 Mixer
PT 10.3.4 + PT 10 HD
MacBook Pro 2.4 GHz Core 2 Duo
OS X 10.8.2
6 GB RAM
Mbox 2 Pro
PT 10.3.4 + CPTK
Old 03-15-2004, 07:58 AM
SelectSound SelectSound is offline
Default Re: digi 002 high pass filter switch
You should try to use the high pass switches when you need to filter out real low frequencies. For example, the manual that came with my Mackie mixer suggests using it on everything except bass drums and bass guitars. Using the high pass keeps the subsonic frequencies from messing with the clarity of a mix. Unless your recording with very low tunings, you should probably always use them on guitars. Also on drum overheads and snares, and vocals.
Q with High Pass filter in Para EQ gtrgriff3 Eleven Rack 2 10-23-2012 01:10 PM
High pass and low pass filter for distorted guitars? adamqlw Eleven Rack 13 09-30-2011 10:35 AM
Low/High Pass Filter Automation Help Funkle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-08-2010 09:23 AM
high pass filter switch on 003 console kt90 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-04-2010 02:52 AM
high pass filter on AUX lamesa VENUE Live Sound Systems 5 01-23-2006 11:01 AM
