worse and worse every day. LE Mbox truly BLOWS!
&*^%$^%&%* white noise screeches out of my monitors at full volume 6 times per day in between fucgin usb holding off audio errors and those are in between cpu holding off interupt errors.
I just upgraded to 6.1.2 hoping that would help. In the first (&*^% 20 seconds of recording i got the deafening white noise again!!!! So pissed it is a wonder i don't walpaper this place with the shattered mbox. Why does this have suck soooooo much? This white noise screech has been talked about for months. Why is it still a problem? imac G4 700, os 10.2.8 PT 6.1.2 recording to internal IDE drive. |
Re: worse and worse every day. LE Mbox truly BLOWS!
i just downloaded the firmware update 2.0 and zapped the mbox. Now it seems to happen more often that i get the white noise!
literally every 10 minutes now. Unusable piece of crap. What is the deal!!!!?????!??!!?!?!?!?! |
That doesn't sound like normal operation, have you contacted digidesign directly? Sounds like you need to give them a call.
are you usung waves plugins?
"I'm one of the few people I know who knows the few people I know" - CL |
I used to have an Mbox which I ran on a G3 iBook (600Mhz, dual USB ports). I found that it made a big difference as to which port I plugged it into.
Just a thought . . .
MacPro 8X 2.26 Ghz cores, 15 GB RAM, OS 10.6.8 PT9/Waves Platinum 8/Waves Restoration Bundle 8, W43/ Cedar DNS One/iZotope Rx2/Odds and ends |
no waves, i'll try a different usb port, as silly as that sounds.
Thanks for the responses. I called digi but their mbox tech line was overwhelmed (i wonder why) they said they couldn't take my call. i wonder if NNNNUUUUUEEEEENNNNDDDDOOOOOOO....................i s any better |
Tomcat,
I have had similar problems with the mbox on my g3 800 iBook since installing LE 6.0. I downloaded the ableton live 3.0 demo last week and I'm floored by it's performance and stability... so I sold my mbox. I will now be using live for all my looping and hard disk recording needs. No offence to Digi, because honestly, I didn't even have the patience to call tech support about my issues with the mbox. Live just seems to be a better fit for the type of recording and composition I'm doing. It just works! -Kevin |
Dude, I'd have to agree about Live. This is one truly sick program...I've been using it for (almost) everything: composition, loop construction, and a performance instrument. I love it...and it gets even sicker when I ReWire it into PT! This combo is a killer one-two punch.
About your mBox...this doesn't sound like normal behavior to me...you might even have a hardware problem. I'd definitely call Digi TechSupport if I were you...
soundphaRm |
[/QUOTE] Well actually I doubt it was hardware trouble because it worked fine in os9. I just find Live to be much more immediate and creative way to create. I sold the mBox for cash to purchase the maudio firewire 410, which will be my interface for Live and Reason. -Kevin |
Come on DIGI!!! this is getting old. It must be a clocking error, because the fix is toggle the clock/input source in the hardware setup. Please let me know you are working on this.
Y'all make Live sound great. I will try it, but my main activity is sound for film, not music. Sounds great though. |
worse results from MboxII to Avid Mbox | anne2501 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-03-2012 03:32 AM |
Mbox 2pro issues - from bad to worse | Maars | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-10-2009 07:42 PM |
Mbox 2 Makes my PC Run even worse than normal!! | brendan2b | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-16-2007 04:05 PM |
WHAT IS WORSE?? | Tell | Tips & Tricks | 4 | 10-10-2001 04:49 PM |
UK always worse off!!!!!!!!!!!!!!!!!!!!!!!!! | Rob Aubrey | General Discussion | 4 | 05-31-2001 03:19 AM |
