no sound from headphones?
i can play back from my monitors but for some reason i get no sound from my headphones.
the headphones are fine, i tried using them on something else i JUST installed pro tools and have made virtally no settings changes yet i have FW 410 win xp laptop |
Re: no sound from headphones?
The only thing I can think of is to go into Sounds and Audio Devices Properties and make sure that the Firewire 410 is the Audio Default device if you also have a Soundcard in your PC. I have a Fasttrack Pro and unless I have that set and the headphones plugged into the Pro I will not hear anything from the headphones. I know that this does not make sense if you are getting output from the monitors but it depends on where the monitors are plugged in. I use mine through my soundcard and change the setting in Audio devices when I play back via the monitors. Only recording via headphones.
Open the M-Audio control panel and make sure the headphones are not muted and are set to get their feed from the main 1/2 outputs.
No Sound Through Headphones | houser8732 | Windows | 12 | 11-02-2013 01:20 PM |
Mbox no sound with headphones?! | Maddern | General Discussion | 1 | 02-23-2011 07:12 AM |
command8 no sound out of headphones | pedrito | Pro Tools M-Powered (Win) | 3 | 08-07-2009 06:02 AM |
no sound from headphones | simon123456789 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-19-2008 05:18 PM |
5.1 surround sound headphones | manis | Post - Surround - Video | 19 | 01-10-2008 04:49 AM |
