Old 05-11-2003, 01:21 AM
chris p chris p is offline
Default Preview Audiosuite
Whenever I preview an audiosuite plug-in the session stops playing.
This is on a Mac OS 9.2 Digi 001
Please help? Thanks. cP
Old 05-11-2003, 02:17 AM
picksail picksail is offline
Default Re: Preview Audiosuite
Whenever a region is highlighted using AS it solos the audio to be processed. It you want to process audio in real time within your mix use RTAS(Real Time Audio Suite) plugs.
Old 05-11-2003, 09:34 PM
Thanks for the response. I checked out a friend's system and I realized that you can't preview without the SR track being soloed. The problem is, when I select "preview", there is no sound at all. Nothing seems to be happening. Is there some special configuration that the buttons need to be set at for this to work correctly (the playlist options etc.)???
Thanks in advance for any help with this. cP
Old 05-12-2003, 12:59 AM
Check your I/O Set Up.
Open up the Output section. Down at the bottem left you will see an audition option. Check this to ensure that the outputs selected correspond with your monitor outputs.
can't ear audiosuite preview, no sound from preview -SOLVED! sonuslab Pro Tools M-Powered (Win) 3 03-19-2008 12:51 AM
audiosuite preview / workspace preview fixed in 7.4? viaspiaggia Pro Tools TDM Systems (Mac) 10 10-11-2007 01:02 PM
Audiosuite preview Lexgotham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-19-2005 01:58 PM
Audiosuite preview manjerie Pro Tools TDM Systems (Mac) 3 10-30-2002 09:20 AM
AudioSuite Preview . . . JEdmunds Tips & Tricks 1 06-20-2001 02:02 AM
