Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Control
Old 07-13-2017, 08:36 AM
Sir Hannes Sir Hannes is offline
Default iPad via lightning cable - not working - how to set up?
following the manual, there's just a chapter about using WiFi. I want to use the cable, but can't see how to set it up. If I connect it and shut down wifi connection - it's still not working.
How can I do that?
Thanks
Johannes
Old 07-14-2017, 02:47 AM
remotedude's Avatar
remotedude remotedude is offline
Default Re: iPad via lightning cable - not working - how to set up?
I got mine working by using an Apple lightning to USB_Power adapter. It's important as you still need to power the adapter. It's an active device and without power it doesn't work. The I plugged an Apple USB to Ethernet adapter into that. Once in you get a menu on the IPAD for Ethernet settings. I've set up static IP's for all and it works like a charm.
Old 07-14-2017, 07:09 AM
I have the same setup, but I can't see a page for the network. Do you mean inside the ProToolsControl App?
Old 07-14-2017, 08:01 AM
reichman's Avatar
reichman reichman is offline
No. Go to the regular iOS settings and you'll see on the top level an Ethernet option. Works really well. And I've never had any need to assign static IPs.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
RHUMBA
www.rhumba.pro
www.nathanielreichman.com
Old 07-14-2017, 10:05 AM
I can't follow, what's the regular iOS settings? When I look in the preference of my iPad there's nothing like an ethernet option. Under "WLAN" I just can activate or deactivate the wifi. Could you please be more specific?
Old 07-14-2017, 10:53 AM
Southsidemusic's Avatar
Here press the "i" Icon on the choose a network second section and there you have ip and such.
Click image for larger version
Best Regards
Christopher
South Side Music Group
WEBHOME
SOUTHSIDEPUB
#ninjakittenshatecrunchyleaves
Eagles may soar, but weasels don't get sucked into jet engines
Old 07-14-2017, 12:37 PM
reichman's Avatar
You won't see it unless you have both the Apple Camera kit which provides USB, and the Apple Ethernet USB adapter (I forget the exact names). When everything is hooked up properly with both adapters, Ethernet appears.
Nathaniel Reichman
RHUMBA
www.rhumba.pro
Old 07-14-2017, 12:48 PM
Okay, thank you guys. Then I misunderstood. I use the lightning on a USB3-Port (active). I thought the ProToolsControl-protocol would take this way, too.
Then I will go on with WiFi. If my project is busy, I used to turn WiFi off to save CPU. But now I will see how it works. The app is great, so I am thankful about that.
Cheers
Johannes
Right-angle Lightning cable Righty27 Pro Tools | Dock 45 06-10-2016 05:39 AM
Avid Scorch for iPad in-app search function not working mbulaong2002 Avid Scorch (iOS) Forum 3 07-11-2012 04:48 AM
Help Avid Scorch App not working with my new Ipad Mixmaster D Avid Scorch (iOS) Forum 1 06-06-2012 05:37 AM
(iPad + AC-7 Core) + (Mac 10.6 + Pro Tools HD 8.1cs1) = Confirmed working. DrFord General Discussion 2 01-04-2011 01:38 PM
Hit by Lightning! vanb777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 07-06-2004 10:49 AM
