Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 07-10-2017, 02:52 AM
info@npp.co.uk info@npp.co.uk is offline
Default M10 Fader meters not working
My S6 M10 fader meters have stopped working. Also meters on main S6 display. Recently updated to 3.6.1 & PT 12.8 on a Mac running 10.12.5. Anyone got a clue how to resurrect them?
Old 07-10-2017, 05:52 PM
EddieJones's Avatar
Default Re: M10 Fader meters not working
The meters use a different pipe than the rest of EUCON so this would most likely be a networking issue. As they are not working on both the Faders and Master Module I suspect its the source(Mac) where you should be looking. Try disabling the Firewall on the Mac first. I presume you have tried a full power cycle ?
Then uninstall WSControl and reinstall as this will reset the network settings.
let me know how you do?
Old 07-10-2017, 09:48 PM
Thanks for this. Will try ASAP
Old 07-11-2017, 09:17 AM
quadraphonics quadraphonics is offline
I had this happen. The S6 needs to be connected to the first network configuration on your Network Panel (System Preferences>Network>Location). Basically, just move whatever connection is being used by the S6 to the top of the list.
Randall
Old 07-11-2017, 09:24 AM
EddieJones's Avatar
Randall
You shouldn't need to do this if the network is configured correctly. How is the S6 network configured on your system, are you using the internal DHCP Server on the S6 or an external router for DHCP ?
Old 07-11-2017, 11:56 PM
The ethernet connection is direct via a Thunderbolt hub. So I assume internal DHCP server. No firewall. Full power cycle not needed as I switch everything off when not being used. It's worked perfectly until 3.6.1. Coincidence? Nothing else changed. It might be worth mentioning that the main screen sometimes flickers - maybe this is part of the same issue.
Tried putting the network configuration at the top - still not good.
Old 07-12-2017, 02:01 AM
Saxon from Jigsaw24 solved the issue. He told me to change the IP address in WS Control, reboot, and then change it back. Hey Presto. All working. But a very strange bug
Old 07-12-2017, 09:36 AM
EddieJones's Avatar
This is a known issue, logging out and back in helps when this happens
Old 07-12-2017, 09:37 AM
EddieJones's Avatar
Great, I'm glad this is solved. The network config must have got messed up. I'll check with the software team as to how this works and see if there's anything that could break.
Old 07-12-2017, 01:20 PM
I am glad the OP got his question answered. Yes, this shouldn't matter - but it does. I have now had to do this on 3 separate M10s. All are using the internal DHCP and are direct connections to the computers controlling them.
Randall
Squiggly Fader Lines on Meters anackman Pro Tools 12 1 12-01-2015 06:53 PM
Master Fader Meters ZoDMeister 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-04-2009 06:26 PM
Mix window meters = pre fader. crsuribe Pro Tools M-Powered (Win) 3 04-29-2008 12:01 PM
Post Fader Meters WaDa TanK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-29-2006 07:20 PM
Mono-Stereo Plug-In Bug with Fader Meters ?!... SimpleNatureSpirit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-06-2004 06:57 PM
