Avid @ NAMM 2018
Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 07-04-2017, 02:41 AM
djelvisteven djelvisteven is offline
Default Talkback mic on avid s6 with xmon and protools
Hi, is there a step by step guide on setting up a dynamic talkback mic on avid S6 with XMON and for use with protools 12?
Old 07-05-2017, 06:17 AM
creativecontrol's Avatar
Greetings,
Your first step is going to be connecting your external TB mic to input 1 on the TB LB UTIL DB25 connection on the back of XMON. From there, you should be able to inject TB into any of the Cues, SLS or engineer Headphone feeds. Press the Monitoring button on the Master Touch Module or the lower Setup button on the control room section to access the Monitoring controls on the Master Module touchscreen.
Jeff
Jeff Komar
Applications Specialist, Pro Audio
S6 XMON/GPI Talkback - How to switch Polarity ? innenhofstudios Pro Tools | S6 4 05-09-2017 09:48 AM
Basic D-command/Xmon internal talkback help TFH ICON & C|24 3 03-07-2017 08:32 AM
avid xmon filip_a Buy & Sell 2 12-12-2016 03:04 AM
Xmon, listen mic and talkback amolin Pro Tools | S6 13 06-16-2016 07:22 PM
System 5MC and XMON Talkback Mic Help Bear Jam System 5 6 11-30-2012 11:15 AM
