Avid @ NAMM 2018
Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Control
Old 07-03-2017, 12:15 PM
Edwin Huet Edwin Huet is offline
Default Issue with Pro Tools & Mackie MCU
Hey all,
Trying out a previously-owned Mackie MCU (version 2.0 firmware) with Pro Tools 12.4.0 on MacOS Sierra 10.12.5.
I've followed the instructions on everything from firmware updating to connecting w/ PT as an HUI interface.
Haven't been able to successfully update firmware. When I play back the MIDI track downloaded from Mackie's site, the display reads "U1)" with a blinking cursor. nothing happens after the file ends or after I stop playback. Tried playing back from PT, Logic, & Ableton, and decreasing tempo.
When I connect to Pro Tools (MCU set to "HUI emulation"), there are always a few random indicators lit on the Mackie, namely pan led's and maybe a mute button or something (always different). I can control track pan knobs with the MCU, but the leds either don't change, or they jump around. Nothing else responds or alters anything in PT (transport controls, faders, etc.). No luck with booting the MCU to "Mackie Control" or "Logic" modes.
I had a little more luck using the MCU with Reaper, where faders sort of worked (jumpy and very, very laggy), and mute, solo, and record arm controls worked. Then again, this was in "Mackie Control" mode.
Any suggestions??
Thanks!
Old 07-04-2017, 08:55 AM
EddieJones's Avatar
Default Re: Issue with Pro Tools & Mackie MCU
Hi, You might have more luck in either Mackie's forums or in the PT forums as most in here are using EUCON controllers. (or you should try out an Artist Mix instead ;-) )
Pro Tools 9 -Mackie Onyx 1640i mixer digital noise issue skylolo99 Pro Tools 9 Discussion 1 08-27-2013 06:04 AM
Eucon connection bug or issue with Mackie Control djmichaelwenz Artist Series 6 12-18-2012 08:51 PM
Mackie defective MCU dimming issue Lawsuit lordtom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-23-2011 07:39 AM
Digi002 Adat clock issue with Mackie D8B BigTizzo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-30-2006 06:31 AM
PT 001/Mackie HDR sync ossillation issue where02190 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-10-2003 12:51 PM
