Old 06-30-2017, 04:03 PM
albee1952 albee1952 is online now
Default Cannot get 10.3.5 to allow Audio Engine setup
Trying to resurrect an older setup for working with RTAS stuff. Windows 7 with PT10.3.5. I have the proper iLok connected and Mbox 2 Pro driver is installed. Mbox shows up as a sound device(and windows is set to NOT use it, leaving it for PT). I hold the N key and start Pro Tools but it never lets me select the Mbox. It just tells me it can't find hardware and only let's me quit. Tried trashing prefs. The Mbox works just fine with PT 12.7 on a different system drive in the same computer. All hardware is good and compatible(been in use with an HDN card for a year). Any ideas?
Asus x99, Intel i7 6800K, 32 gig DDR4, GeForce 750 Ti, HD/Native, HD IOx2, PT11HD, UAD Quad, preamps from Vintech, Five Fish Audio, Miktek, Focusrite, Chameleon Labs and Midas..............................
www.capricornsoundworks.com
Old 06-30-2017, 04:12 PM
Drew Mazurek's Avatar
Can you try the HD Native card with PT10? Is it a perpetual license? Subscription won't auth PT10 remember.
What happens if you let PT launch with another playback engine, does the MBox show then?
Throwing out ideas as they come to me.
www.drewmazurek.com
Old 06-30-2017, 04:23 PM
Default Re: Cannot get 10.3.5 to allow Audio Engine setup
Can't do the card as its in another system now. I have the proper PT10 license on an iLok(already fixed that issue by updating iLok software). The problem is that I can't get to the window to select any audio engine
Old 06-30-2017, 04:27 PM
PT can't launch with the built in audio? Sorry, don't know about PCs.
www.drewmazurek.com
Old 06-30-2017, 04:30 PM
Normally, it can, but something abnormal is going on
Old 06-30-2017, 04:31 PM
And launch without the N key does what? Nothing? Freeze? Crash?
www.drewmazurek.com
Old 06-30-2017, 04:38 PM
Exactly the same as with. Says unable to find hardware. Click OK when hardware is ready. Going to try a re-install. Fingers crossed
Old 06-30-2017, 04:39 PM
Cool. Good luck!!
www.drewmazurek.com
Old 06-30-2017, 05:07 PM
FAIL! Can't select any audio engine. So much for that idea. Stuck in the system drive with PT12.7 and it works fine......I'm done for the night
No m-audio interface in current engine (playback engine) SlicerSounds Pro Tools Software (Win) 1 10-04-2012 12:27 AM
Playback Engine Setup Problem in PT 7.4.2 MattCraft Pro Tools TDM Systems (Mac) 1 07-07-2010 01:47 PM
Playback Engine Setup Xhalo0zero Pro Tools TDM Systems (Mac) 8 12-08-2008 04:20 PM
Help - HD Playback Engine Setup Crashes Richard Eshelman Pro Tools TDM Systems (Mac) 6 11-21-2002 02:10 PM
Pb with Playback engine Setup Maat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-12-2001 01:22 AM
