Avid @ NAMM 2018
Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 10 Discussion
Old 06-26-2017, 07:46 PM
springthing springthing is offline
Default Help needed with upgrade versions compatibility
I have happily been using PT v9 on OSX 10.6 for many years, and my iMAC hardware system isn't new, but the overall performance has been rock solid so I've resisted upgrading both the software and hardware. I'm not a power user so I haven't been motivated to stay up with the latest and greatest
I recently purchased Izotope's Music Production Bundle 2, and failed to check compatibility, only to find it needs a newer OSX and PT.
I'm keen to try and only upgrade as high as PT10, to still have the option of RTAS plugins, and plus also that's all I think I need. But I'm finding it difficult to confirm which is the ideal OSX to ensure I can use PT10 with RTAS support, along with IZotope's bundle.
Izotope's specs say for Neutron Advanced to work you must have OS X 10.9–10.12, and Pro Tools 10-12
https://www.izotope.com/en/products/...dle/specs.html
However Avid's compatibility chart, shows that PTs 10 is not supported after OSX 10.8.5
http://avid.force.com/pkb/articles/c...tibility-Chart
So from user experience here, can anyone recommend, which version of OSX/PT combination I should aim to upgrade to solve my situation???
I know the 'simple' option is to just do away with RTAS support, and go with the latest supported version of OSX and PT, but I'm also worried how that is going to affect my aging machine's performance...
Any suggestions would be most appreciated.
Mike
Old 07-08-2017, 09:42 AM
Default Re: Help needed with upgrade versions compatibility
...Bump
...Any advice would be appreciated
Old 07-08-2017, 12:29 PM
Manu101 Manu101 is offline
PT10 works with OSX 10.9 (see this post:)
Originally Posted by JFreak View Post
PT10 and Mavericks is a *WORKING* configuration. It is not officially supported due to known issues, but it works. Most notable issue is with the uninstaller so that makes updates a little harder to do, but for most part, PT10 WORKS with 10.9
Now if you want to stay clean and update PT10 to new version whenever one comes out, here's what you should do:
- Backup everything and make a super fresh clean install of Mavericks
- Install every software you need to use, EXCEPT PT10
- Clone that system drive to some disk image
And once new PT10 update is out, just clone back from your super fresh system drive disk image and install PT10.
From experience, PT10 will not run well on Yosemite (10.10)
Manu
i7 7800X - Win10 - PT12HD - TC Electronic Studio Konnekt 48 - 2x MC Mix, 1x MC Transport, Pro tools Control app on an Ipad mini 2 - Equator D8 5.1 system - Tannoy TS10 Sub
Old 07-08-2017, 07:03 PM
Ben Jenssen's Avatar
I would stick with what you got. You know it's working. Find another way to acheive wat you wanted with izotope, and sell the bundle. I really don't think there's a wy to make it worK, what you're wanting; a incremental upgrade of old both OS and PT.
Old 07-09-2017, 05:39 AM
@ Manu101
Thanks for raising that existing information. I had also seen something on the Avid site (under compatibility) stating the same thing, where 'PT10 WORKS with 10.9' albeit without the uninstall feature. Which I don't see as a big deal. I just need a working version! It certainly seems worth trying to install version 10.3 to see how it runs.
@ Ben
That's more or less what I've been doing since version 9, just sticking with what I've got, and it has been rock solid. But I'd like to start incorporating the iZotope software (I'm a big fan of their products), which they have confirmed doesn't run on Pro Tools 9
My best bet, seems to be trying to get a set up running OSX Maverick 10.9, and hopefully seeing if I can get a stable version of PT10 to run on this OSX, which should run my old RTAS plug ins and the latest iZotope Production Bundle...?
Old 07-09-2017, 05:50 AM
Not shure if it's even possible to buy 9-10 upgrade anymore.
Old 07-10-2017, 02:51 AM
If I read it correctly here - http://shop.avid.com/ccrz__ProductDetails?sku=DYNA20008
It comes with licenses for 10/11/12.
Old 07-11-2017, 10:14 AM
panamajack's Avatar
panamajack panamajack is offline
I have PT10.3.10 HD3 running under Mavericks. I also used the manual "uninstall" to remove PT10HD, on a system which had been upgraded to El Capitan, and the uninstall worked without hitch from an MP tower. The graphics pull-down windows got weird when I ran PT10 on Yosemite, but PT11 runs okay on Yosemite.
I have two 4K monitors running under Mavericks with a Radeon HD5870. Not a great card, but with Mountain Lion I could only get one 4K monitor and one 2K monitor to work. The video drivers in Mavericks are upgraded and some of the plug-ins require Mavericks.
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.3.3;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.5+, Finale25,EMU,Vegas Pro 14-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon
Mac Versions compatibility dedalus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-29-2011 07:06 AM
PT 8 HD/PT9 Compatibility, 10.6.5 compatibility, OMF Logic9/PT9, iLok upgrade benosullivan Pro Tools 9 Discussion 2 11-17-2010 12:05 PM
McDSP: Compatibility across PT versions RenderBot Post - Surround - Video 7 07-19-2006 10:41 AM
session compatibility between versions AND platforms Craig5024 Tips & Tricks 1 07-22-2003 01:12 PM
PT versions compatibility blanos112 Pro Tools TDM Systems (Mac) 3 04-09-2002 06:50 AM
