Avid @ NAMM 2018
Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 06-20-2017, 05:16 PM
EddieJones's Avatar
Default S6 v3.6.1 Software Released
V3.6.1 is now in your Avid accounts. This is mainly for PT 12.8 and Dolby Atmos compatibility but there are a couple of other features and bug fixes.
• Increased Expand Faders from 8 to 16
• Assign Right Joystick Timeout setting
Issues Resolved in S6 v3.6.1
• It could be difficult for some plug-in knobs to reach their maximum and minimum values
• It was possible for registry permissions issues to prevent WSControl from recognizing a workstation when installed on a cleanWindows OS
• Changing Network Ports on the Master Module required two reboots
• It was possible for the Automation Module wheel to become incapable of scrolling the Pro Tools MIDI Editor window vertically
If you are currently on v3.5 or v3.6 and on an active support contract, all you need to do is install the software, no activation needed.
In order to install the v3.6.1 software update you will need your S6 console to be on a current Avid Support Plan. Your console came with 1 year of Avid Advantage ExpertPlus support with Hardware Coverage so please check your support plan expiration date. There are several options for renewing coverage (even if your plan has recently expired). If you are a registered owner, you will receive an email with details or you can contact Avid directly to hear about your options at : 1-650-218-4058
Old 06-27-2017, 08:55 AM
Juan Garcia Juan Garcia is offline
Default Re: S6 v3.6.1 Software Released
Hi!
In the What's New PDF there's a new soft key for the master and automation modules. I was trying moments ago and couldn't find the new soft key por preferences. Shift and * didn't do anything on the soft key banks. Any ideas?
Best,
J.
PS: so sad Optn+touch on sends was only affected on EuControl and not on S6
Old 06-27-2017, 10:47 AM
creativecontrol's Avatar
Greetings,
You can access the global preferences QuickJump (which I believe is what you are referring to) by holding down one of the SHIFT LED switches on the Fader Modules while pressing the * key which is located in the numeric section of the Master Automation Module. This will utilize all of the Master Touch Module and Master Automation Module soft keys to let you toggle console preferences.
Can you elaborate on your statement regarding defaulting of Sends on S6? I presume this has to do with the preference for sends default to - INF vs the currently nulling behaviors. Please let us know. Thanks!
Jeff
Jeff Komar
Applications Specialist, Pro Audio
Old 06-27-2017, 12:48 PM
EddieJones's Avatar
The Send clear issue will be fixed in the next release sorry.
Old 07-04-2017, 07:48 AM
Strange. The Quickjump didn't work the first time I tried it. It's working well now. I guess it just needed a restart.
Thanks,
J.
Old 07-05-2017, 06:20 AM
There is a slight latency for S6 to recognize that you have engaged a modifier key on the Fader Module before pressing a switch in the numeric section. I presume this is what you've experienced.
best,
Jeff
Jeff Komar
S6 V3.6 Software Released EddieJones Pro Tools | S6 5 06-14-2017 06:27 PM
S6 v3.6 Software Released EddieJones Technical Alerts 0 04-13-2017 01:33 PM
12.5.2 released MIKEROPHONICS Post - Surround - Video 5 07-09-2016 10:36 AM
BFD 2.2 released guitardom General Discussion 0 12-11-2010 04:39 PM
When is 5.1 released? juneaudio General Discussion 8 10-16-2000 05:33 PM
