Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 05-08-2017, 12:49 AM
innenhofstudios innenhofstudios is offline
Default S6 XMON/GPI Talkback - How to switch Polarity ?
Hi Guys,
Just installed the 3.6 update.
In 3.5 i was able to reverse polarity for Talkback by pressing "Talk" in the XMON App.
Since 3.6 i permanelty have talback enabled when not pressing the pedal.
Does anyone know how to switch polarity ?
Thanks in advance.
Best Rene
www.innenhofstudios.at
Old 05-08-2017, 09:34 PM
EddieJones's Avatar
Default Re: S6 XMON/GPI Talkback - How to switch Polarity ?
This was a bug...talkback would get switched on without a user knowing it so we removed the check from the XMON App. Is your foot switch normally closed or open...does it have a setting to change it ?
Old 05-09-2017, 08:34 AM
Hi Eddie,
our pedal is standard "Closed" and i cannot change the setting :/
Old 05-09-2017, 08:50 AM
EddieJones's Avatar
That's a shame. Unfortunately the GPIO is designed for a normally open switch. It was just luck that the bug helped you out...but it caused a lot of bad issues for other customers when talkback was on without the user knowing. Can you get another pedal ?
Old 05-09-2017, 09:48 AM
already ordered a new one
thanks for your help
best r.
Xmon, listen mic and talkback amolin Pro Tools | S6 13 06-16-2016 07:22 PM
System 5MC and XMON Talkback Mic Help Bear Jam System 5 6 11-30-2012 10:15 AM
External talkback mic/switch/cuelight switch Pete Gates Post - Surround - Video 3 03-16-2011 01:53 AM
EQIII - Polarity Switch doesn't bypass. allstaar Pro Tools TDM Systems (Mac) 0 06-05-2007 02:44 AM
Implementing a polarity switch on each track? Berrado Pro Tools TDM Systems (Mac) 12 04-24-2007 03:19 PM
