Old 04-24-2017, 12:13 AM
chris1008895 chris1008895 is offline
Default Unable to install software Error message
I am unable to install my protools 9 software, I am also unable to install any of the included device drivers
The following message appears when I try to install:
"An incompatible version of the operating system was found"
"requires 10.6.2 or higher"
I have 10.12.4 mac OSx
I have downloaded the latest device driver from the avid website, this doesn't appear to have done anything
What should I do? Any advice would be greatly appreciated
Old 04-24-2017, 12:21 AM
Default Re: Unable to install software Error message
Pro Tools 9 is not compatible with macOS Sierra. You need to upgrade to Pro Tools 12 if you want to run in Sierra. If you just upgraded the OS you can rollback to your last working backup. If you brought a new Mac... well you need to upgrade to Pro Tools 12. And next time check compatibility before you upgrade anything. Links to compatibility tables are up the top of this DUC web page.
[IMG] code is Off
unable to access software updater message? kennai Pro Tools Software (Mac) 4 07-16-2013 09:20 AM
Error message: Unable to create new sessions 92_Adri Pro Tools Express on Mac OS X 1 10-08-2012 12:51 PM
Error Message on PT8 Install & PLAY Install blizzard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 02-22-2010 05:16 PM
Unable to communicate with Digi 002 error message Raul Offendi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-30-2004 05:01 PM
error message unable to retrieve scorpiomoon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-20-2004 06:44 PM
