Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | Control
Old 04-16-2017, 09:35 AM
m4tune m4tune is offline
Default Eucon v.3.6. "copy" doesn't work
Multiple Eucon commands
Copy the selected part of a clip does only work once. Next time the first copied selection stays in the "clipboard" and is not replaced by new selection
When copied by keyboard cmd-c everything is normal.
But even when this (cmd-c as a key stroke) is integrated in a series of actions in Eucon the clipboard is not being updated…
Mac Pro 5,1 12 Core 3,46 GHz MacOs 10.13.3, 64GB Ram, Angelbird Wings x2, PT HDX, HD I/O, 2x 192i/o, 2x Digi Pre, 2x Artist Mix. Artist Transport
http://www.4tune.at
Old 04-17-2017, 08:58 AM
EddieJones's Avatar
Default Re: Eucon v.3.6. "copy" doesn't work
Can you share the complete Macro ? I'll give it a try here.
Old 04-18-2017, 01:47 AM
Shure. Here's the link with the Macro and an example how it acts:
https://drive.google.com/drive/folde...jA?usp=sharing
http://www.4tune.at
Old 04-18-2017, 02:56 AM
Hi Eddie,
after a modification of the Macro (deleting the first command "copy" and doing this by hand now) I figured out the next problem:
I want to move the cursor back to the upper tracks (last 2 commands in Macro 2) I get more weird results. Please see Pictures 04-07 here:
http://www.4tune.at
Old 04-18-2017, 06:26 AM
Cheesehead Cheesehead is offline
My guess is Eucon probably needs a 'Wait' command to insert between some Eucon commands, similar to the one Keyboard Maestro has.
Eucon just bashing out a high speed string of keyboard shortcuts, is never going to work on stuff that takes time to accomplish.
Having said that, it does work fantastically for some macros and I'm very pleased they've included it in this release.
Mac Pro 6,1 12 core, OSX 10.12.4, Sonnet Chassis, HD-Native TB, 888, 192, Sync HD, AJA LHi, MC Mix, PT Control, Eucon 3.7, PT 12.8.2
Old 04-18-2017, 09:24 AM
EddieJones's Avatar
Cheesehead is correct, I think its acting too fast, luckily we do have a delay command in the works. You could try adding a keyboard command /a in between each EUCON command ?
Old 04-18-2017, 10:34 AM
Tried both: /a between each command and \a from the commands-menu in Eucon. It's the same. /a deactiates my group a but still the same behaviour.
Anything you could check according the "copy" issue?
http://www.4tune.at
Old 04-18-2017, 10:48 AM
EddieJones's Avatar
Its firing the commands one after the other as fast as the computer can, I'm afraid we'll have to get the delay command in before it will work well for everything.
Old 05-15-2017, 10:16 PM
Hi Eddie,
do you have any idea when the pause command could be available?
http://www.4tune.at
Old 05-18-2017, 09:40 AM
EddieJones's Avatar
We were trying to squeeze it into 3.6.1 next month but it turned out to be more work than we thought so will have to be in 3.7, later in the year. Sorry.
"Tuner" and internal "DSP" doesn't work on Mbox 3 Pro luckydjacks FireWire and USB Audio Interfaces (Win) 129 06-20-2014 03:25 AM
3tuner" and internal "DSP" doesn't work on Mbox Pro (3G) luckydjacks Pro Tools Software (Win) 0 12-31-2012 04:40 AM
Need work-around: "EuCon will not function well after sleep" jasperhb Artist Series 18 05-31-2012 08:48 PM
Toggle Track view ("Opt"+"-") doesn't work LukeFromBerlin Pro Tools Software (Mac) 3 04-01-2012 04:43 AM
why doesn't "control/click" work on midi regions? tunespin MIDI 2 11-19-2009 08:09 PM
